Nonlinear electric susceptibility and degenerate frequencies
The discussion centers on the concept of distinguishability of frequencies in the nonlinear electric susceptibility tensor, particularly in the context of second harmonic generation (SHG) with collinear and non-collinear beams. It is clarified that while the second-order susceptibility is material-specific and does not depend on the external field, the propagation direction of the beams can lead to different effective susceptibilities and phase matching conditions. The conversation also touches on the calculation of nonlinear source polarization, noting that different propagation terms arise when considering beams with varying directions. There is uncertainty about deriving a similar expression for effective susceptibility when beams cross, with a reference to a resource for further understanding. The complexities of nonlinear optics and the implications of beam directionality are emphasized throughout the discussion.
Yorre
Hi there,
I'm having a little trouble understanding the "distinguishability" of frequencies in the nonlinear electric susceptibility tensor. As far as I understand, if we have a SHG process with two collinear beams of the same polarization and frequency ω, there is only one susceptibility component 2ω;ω,ω. But if these beams propagate to different directions, still with the same frequency ω, must we label the frequencies as ω1 and ω2 and end up with components 2ω;ω1,ω1 , 2ω;ω2,ω2 , 2ω;ω1,ω2 and 2ω;ω2,ω1? So can the propagation alone make the beams distinct?
Thanks in advance!
The second order susceptibility, as well as susceptibility in the other orders, are material specific and is not dependent on the external field. So, I believe propagation direction should not change the value of ##\chi^{(2)}(2\omega;\omega,\omega)##. The quantities which will look different for different propagation alignments are, among others, the effective susceptibility and the phase matching condition.
Likes Yorre
Thanks for the reply, blue_leaf. So when calculating the NL source polarization, the complex amplitudes of the two fields create four propagation terms (1,1), (1,2), (2,1), (2,2) and four phase matching conditions, while the effective susceptibility can be taken as the common factor when both fields have the same polarization?
Sorry, I forgot that the effective susceptibility ##d_{eff}## was defined when the two beams are propagating in the same direction, and it reads
P(\omega_3) = d_{eff}E(\omega_1)E(\omega_2)
where ##P(\omega_3) = |\mathbf{P}(\omega_3)|## and ##E(\omega_i) = |\mathbf{E}(\omega_i)|##. For crossing beams, I am not sure if you can derive a similar expression which relates the magnitudes of the polarization and fields like that above. An example of the derivation of ##d_{eff}## can be found in "Applied Nonlinear Optics" by Zernike and Midwinter for some cases. May be you can derive ##d_{eff}## for general case of crossing beams.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
