Misc. Nonlinear rubberband type thing - "k" dropping fast as it is stretched
  • Thread starter Thread starter Swamp Thing
The discussion focuses on finding materials that can produce a specific displacement versus force curve, resembling the behavior of a piston inflating a balloon. Participants are seeking durable options that can withstand at least 100 stretch cycles without being messy, ruling out liquid-based colloidal materials. Suggestions include experimenting with silicone and potential additives to achieve the desired characteristics. There is also clarification on the axes of the graph, confirming that displacement is on the x-axis and force on the y-axis. The conversation hints at the implications of reversing these axes, suggesting interesting hysteresis effects.
Swamp Thing
Insights Author
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this..
(of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here).
I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or something that exists commonly or is available on Amazon?
A piston in a cylinder, like a bicycle pump, that is connected to a balloon. As the piston moves, high pressure is needed to begin inflating the balloon, then the pressure falls rapidly as the balloon volume rises.
Likes Swamp Thing
the graph is not labelled.
Is stress ( force ) along the y-axis, and strain ( displacement ) along the x-axis ?
Likes sophiecentaur
Sorry... X is displacement and Y is force.
(If it was the other way round, there would be some interesting hystereses type things going on I guess)
That response is like a symmetrical over-centre latch.
Are the units mg, g, kg, tonne or N ?
Likes sophiecentaur
I just arrived here and was wanting to put your comment in. You'd done it already!
Rubber bands will not all behave the same. I would say that a spring and cam would do what you want - very reliably. As in the above, the magnitudes of force and displacement will determine how you actually realise the design.
The idea is to use water to shift the centre of gravity of the pendulum by a small amount. The pendulum rod will have a tube closed at the bottom and open at the top. A second similar tube will be mounted nearby and will act as a reservoir. The water will be transferred using a peristaltic pump driven by a stepper motor and will travel via a thin flexible silicon tube. A loop arrangement will minimise friction at the pendulum's fulcrum. The silicon tube will extend to the bottom of the...
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
