Normal modes of four coupled oscillating masses (Kleppner and Kolenkow)
The discussion revolves around a problem from Kleppner and Kolenkow regarding the normal modes of four coupled oscillating masses. The user is comparing their derived equations of motion with those from a solution key, which appear to be inconsistent, particularly regarding the forces acting on the second mass. The user believes their equations correctly account for the interactions between adjacent masses, while the solution key omits certain terms. Ultimately, it is confirmed that the solution key is incorrect, and the user is encouraged to utilize the symmetry of the system to determine the normal mode frequencies. The thread highlights the importance of careful analysis in deriving equations of motion for coupled oscillators.
dford
Four identical masses ##m## are joined by three identical springs, of spring constant ##k##, and are constrained to move on a line, as shown.
There is a high degree of symmetry in this problem, so that one can guess the normal mode motions by inspection, without a lengthy calculation. Once the relative amplitudes of the normal mode motions are known, the normal vibrational frequencies follow directly.
Because of the symmetry, the normal mode amplitudes must obey ##x_1 = \pm x_4## and ##x_2 = \pm x_3##. Another condition is that the center of mass must remain at rest. The possibilities are:
##(x_4 = x_1)## and ##(x_3 = x_2)##
##(x_4 = -x_1)## and ##(x_3 = -x_2)##
The normal mode equations lead to three possible non-trivial vibrational frequencies and three corresponding normal modes. Find the normal mode frequencies. It is convenient to use the dimensionless parameter ##\beta = \omega^2/\omega_0^2##, where ##\omega## is the frequency to be found and ##\omega_0 \equiv \sqrt{k/m}##.
Hooke's Law and harmonic oscillation: ##m\ddot x = -k(x-x_0)##, where ##x_0## is the equilibrium position for a spring. The general solution to this ODE is ##x(t) = A\sin(\omega t + \phi)##, where ##\omega = \sqrt{k/m}##.
This exercise comes from Kleppner and Kolenkow, 2nd ed., problem 6-3. I'm using a solution key as a study reference, but the solution key is coming to a pretty different conclusion. Mostly the issue is in the equations of motion for this system. I'm not sure if there's something I'm fundamentally misunderstanding, or if the solution key is wrong.
Each ##x_i## is the displacement of the ##i##th mass from its equilibrium. So for example if ##x_1 = x_2##, then the first spring is unstretched even though the first two masses are displaced from the system's equilibrium.
I beieve that the equations of motion are:
\begin{cases}
m\ddot x_1 = k(x_2 - x_1), \\
m\ddot x_2 = -k(x_2 - x_1) + k(x_3 - x_2) = k(x_1 - 2x_2 + x_3), \\
m\ddot x_3 = -k(x_3 - x_2) + k(x_4 - x_3) = k(x_2 - 2x_ + x_4), \\
m\ddot x_4 = -k(x_4 - x_3).
\end{cases}
Each mass oscillates according to the equation ##\ddot x_i = -\omega^2 x_i## in a normal mode, where ##\omega## is the frequency shared by all masses. Letting ##\omega_0 = \sqrt{k/m}## and ##\beta = \omega^2/\omega_0^2##, and making the substitution ##\ddot x_i = -\omega^2 x_i## and dividing by ##\omega_0^2 = -k/m##, the above equations become:
\begin{cases}
\beta x_1 = x_1 - x_2, \\
\beta x_2 = 2x_2 - x_1 - x_3, \\
\beta x_3 = 2x_3 - x_2 - x_4, \\
\beta x_4 = x_4 - x_3
\end{cases}
And the idea is now to use the symmetry in the cases ##x_4 = x_1, x_2 = x_3## and ##x_4 = -x_1, x_2 = -x_3## to find ##\beta##.
However: The solution key I'm using as a reference has different equations of motion and different conclusion and I'm not following it. I quote it below (they're missing some negative signs but these cancel out):
For the harmonic motion of each mass, ##\ddot x_i = \omega^2 x_i##. The equation of motion for mass 1 is, for example,
m\ddot x_1 = k(x_1 - x_2) \Longrightarrow \omega^2 x_1 = \frac k m (x_1 - x_2) \omega_0^2(x_1 - x_2)
\beta x_1 = (x_1 - x_2)
where ##\omega_0 = \sqrt{k/m}## and ##\beta = \omega^2/\omega_0^2##. Hence
\beta x_1 = (x_1 - x_2) \quad \beta x_2 = (x_2 - x_1 - x_3)
\beta x_3 = (x_3 - x_2 - x_4) \quad \beta x_4 = (x_4 - x_3)
But this to me suggests that their equation of motion for the second mass, for example, would be ##m\ddot x_2 = k(x_2 - x_1 - x_3)##. Shouldn't the second mass feel the effect of both springs on either side, as I observed in my equations of motion? Or did I miss a coefficient somewhere?
UPDATE:
As someone pointed out in the link below, yes, the solution key is wrong. Thanks all :smile:
Homework Statement: Four identical masses ##m## are joined by three identical springs, of spring constant ##k##, and are constrained to move on a line, as shown.
Relevant Equations: Hooke's Law and harmonic oscillation: ##m\ddot x = -k(x-x_0)##, where ##x_0## is the equilibrium position for a spring. The general solution to this ODE is ##x(t) = A\sin(\omega t + \phi)##, where ##\omega = \sqrt{k/m}##.
Note: I edited the above to get the MathJax input sorted out. Good thing you know ##\TeX## ! In PF MatJax the delimiter for inline math is ## and for displayed math you have $$ as delimiter. Apparently you know already, because you did well in
dford said:
I'm just seeing if this will work: x¨=−kx, or x¨=−kx.
which is a start. I don't see ##x## in the exercise, only ##x_1## etc. :wink:
Check out the treatment of a slightly simpler configuration here
(:smile: as you can see physicists are lazy buggers -- if possible they let google do their work for them)
Yes indeed; even math.stackexchange uses slightly different mathjax syntax. I think I figured it out. Thanks :)
Aha, and in fact your link answered my confusion. Good to know I understood that much at least :wink:
The thread of this thread is now a bit hard to follow -- not unusual within PF, but what can one do ?
Well:
  • mark/indicate major edits
  • don't add big chunks in a post if subsequent posts then become unhinged
  • In a 'reply', remove irrelevant parts to keep the volume of repetitious stuff limited
  • use common sense :wink:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
