Normal modes of square membrane
In summary: To get a node along y = 1 - x, try um,n(x,y,t) ± un,m(x,y,t) with y = 1 - x.In summary, the conversation is discussing how to show that there can be nodes along the diagonals of a square and a triangular membrane by combining two solutions and using the double angle identity for sine. The conversation also explores how to find the fundamental mode for a triangular membrane.
bon
559
Please see question attached
Ok so I've been able to do the first few parts and have derived that Wm,n = c pi / L (m^2 + n^2)
I've thus been able to show that the second lowest freq is a factor of root(5/2) times larger than the first and that there are two modes that have this frequency. But how do you do the next two parts?
How do I show that by combining them it is possible to have a node along either diagonal of the square? I guess I have to add the two solutions and subtract, but then how do I show that these nodes are along the diagonal?
Also what about the last part? How am i meant to deduce the fundamental mode for a triangular membrane?
Thanks!
  • modes of a square membrane.pdf
OK so I've been able to do the first few parts and have derived that Wm,n = c pi / L (m^2 + n^2)
Thanks!
It looks like what you have so far is:
um,n(x,y,t) = Am,n·sin(mπx/L)·sin(nπy/L)·cos(ωm,nt), where ωm,n = (cπ/L)·√(m2 + n2).
You actually had ωm,n = (cπ/L)·(m2 + n2), but since you got the correct ratio, I assume you inadvertently left out the radical. I also took the liberty to include subscripts on u(x,y,t) to indicate what values of m & n are used.
Notice, that if um,n(x,y,t) is a solution to the equation, then, of course, so is un,m(x,y,t).
Not only that, um,n(x,y,t) ± un,m(x,y,t) are also solutions.
In particular, look at u1,2(x,y,t) - u2,1(x,y,t).
Use the double angle identity for sine. Do some factoring, then use the identity:
cos(θ) - cos(φ) = -2·sin((θ+φ)/2)·sin((θ-φ)/2)
That will get the node along the y = x diagonal.
As for the last question: What does it mean for there to be a node along a diagonal?
Edited to add:
It occurs to me that to check for a node along the diagonal y = x, for instance, it may be simpler to simply plug in x for y in um,n(x,y,t) ± un,m(x,y,t), and see if the result is zero.
The other diagonal occurs along the line: y = 1 - x.
FAQ: Normal modes of square membrane
What are normal modes of a square membrane?
Normal modes of a square membrane refer to the different patterns of vibration that can occur in a square-shaped membrane when it is excited by an external force.
What factors affect the normal modes of a square membrane?
The normal modes of a square membrane are affected by factors such as the size and shape of the membrane, the tension of the membrane, and the material properties of the membrane.
How are the normal modes of a square membrane calculated?
The normal modes of a square membrane can be calculated using mathematical equations that take into account the dimensions, tension, and material properties of the membrane.
What is the significance of normal modes of a square membrane?
The normal modes of a square membrane have practical applications in fields such as acoustics and structural engineering. They also help us understand the complex behavior of vibrating structures.
How do normal modes of a square membrane differ from other types of normal modes?
Normal modes of a square membrane differ from other types of normal modes (such as those of a circular or rectangular membrane) in terms of the specific patterns of vibration that they exhibit.
