Normality of (COONa)2 - KMNO4 titration (redox reaction)
The discussion centers on calculating the Normality of a (COONa)2 solution using a KMnO4 solution of 0.01 Normality. The equation N1V1=N2V2 is proposed for this calculation, where 14ml of KMnO4 is used to titrate 10ml of the (COONa)2 solution. There is consideration of the stoichiometry of the redox reaction, questioning whether to adjust the equation with a coefficient of 5/2 due to the equivalents involved. It is noted that 0.01N permanganate equates to 0.002M, and that the Normality of oxalate is twice its concentration in redox reactions. However, the ambiguity of Normality is acknowledged, with a caution that its use has been discouraged by IUPAC and other organizations for over 40 years.
Man0uzz
We used 14ml of a KMNO4 solution of 0.01 Normality, to find the Normality of a (COONa)2 solution.
If we took 10ml of the (COONa)2 solution, what should its Normality be?
I thought about using the following equation: N1V1=N2V2
Does the stoichiometry of the redox reaction affect the equation above? Should we multiply N2V2 with 5/2 because of it?
Chemistry news on Phys.org
Most likely 0.01N permanganate is actually 0.002M (five equivalents per mole), and normality of oxalate is twice its concentration (two equivalents per mole in redox reactions). If so equation as written should work with no additional stoichiometric coefficients.
But you are right that normality can be ambiguous and sometimes depends on the context, so treat above just as a guess.
AAmmmeeeennnnn.
And I think therefore its use is discouraged for at least 40 years by IUPAC and other organizations...
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
