Notation within homework question
  • Thread starter Thread starter mike_302
    Homework Notation
The discussion centers on the notation of potential energy U(x,y) given by U(x,y)=2x + x^3, where the participant questions the relevance of the y variable since the solution only involves x. The correct interpretation of change in potential energy is clarified as U(initial) - U(final), aligning with the principle that change equals initial minus final values. The notation is defended as appropriate for functions of multiple variables, despite the specific problem relying solely on x. Ultimately, the participant acknowledges understanding the work-energy relationship while still finding the notation confusing.
mike_302
A particle moving along the x-axis is subject to a conservative force such that the potential energy of the particle is given by U(x,y)=2x + x^3 where x and y are in meters, U is in joules. When the particle moves from (2,0) to the origin, the work done by the conservatice force is:
A) b) c) d) (the choices don't matter... I have the right value, wrong sign)
delta(U) = change in potential energy.
Okay, my real question here is: What does this notation U(x,y) really mean?
And I checked the solution for this problem, and it says U(initial) - U(final)... Why is this? Since when is the change in a value equal to initial - final ?
The notation U(x, y) is used to indicate that U is a function of two variables, x and y. The formula you show, however, is a function of x alone.
Is there a typo in this formula? Should it be U(x, y) = 2x + y^3?
mike_302 said:
… I checked the solution for this problem, and it says U(initial) - U(final)... Why is this? Since when is the change in a value equal to initial - final ?
Hi mike_302! :smile:
(try using the X2 tag just above the Reply box :wink:)
Change in potential energy = minus the work done
ie ∆PE = -W
so the work done will be -∆PE = Uinitial - Ufinal
Okay, I completely see why it's Ui-Uf now but that U(x,y) notation seems messed up because there's no typo :P That's how it is written, and I get the answer using JUST x, so I guess it should've said U(x)= ...
Oh well!
mike_302 said:
… that U(x,y) notation seems messed up because there's no typo :P That's how it is written, and I get the answer using JUST x, so I guess it should've said U(x)= ...
No, because potential is a function of position, and has to be defined at every position …
for example gravitational potential is U(x,y,z) = -gz. :wink:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
