Undergrad Notion of parallel worldlines in curved geometry
The discussion explores the concept of parallel worldlines in the context of curved spacetime, emphasizing that geodesic deviation is key to understanding this notion. It highlights that two worldlines must start parallel in spacetime, specifically in tangent spaces at their initial points, to evaluate their geodesic deviation accurately. The conversation also questions whether the definition of parallelism applies to non-geodesic worldlines, noting that no widely accepted definition exists for such cases. Additionally, it suggests that in non-Euclidean geometry, parallelism for geodesics does not necessarily require constant distance between the worldlines. The topic ultimately delves into the complexities of defining parallelism in curved geometries.
cianfa72
TL;DR
About the notion "to be parallel" in the context of curved geometry
The notion of spacetime curvature is just the same as geodesic deviation. Therefore take for instance two bodies at different altitudes from Earth surface. In order to evaluate their geodesic deviation the two worldlines must start parallel in spacetime (actually in tangent spaces at both initial points/events).
We know in curved spacetime the notion of "to be parallel" is path dependent and it is given by the affine connection assigned to the spacetime as metric manifold (i.e. the Levi-Civita connection derivated from the metric tensor ##g## is normally used).
That said, which is the relevant/implied path to say that the two worldlines start parallel ? I believe it is the geodesic path one gets exponentiating the (spacelike) vector orthogonal to the first worldline's 4-velocity at its starting point that intersect the other worldline at its starting point.
cianfa72 said:
TL;DR Summary: About the notion "to be parallel" in the context of curved geometry
Usually you can only make such a statement when those two worldlines are initially close enough that you can treat them as being in a flat spacetime. Then it is unambiguous.
Likes robphy and cianfa72
Ok. Does the above definition of parallelism apply also to non geodesic worldlines as well?
Take for instance two concentric circles on the euclidean plane. From any point on the bigger one, draw the orthogonal straight line to the other circle getting a point.The tangents to circles on both points stay always parallel.
I have never seen a definition of parallel that would apply to non-geodesics. There might be one, but I don't know of it.
Does the definition of "to be parallel" for geodesics also demand that the distance/lenght along the orthogonal geodesics between them at any point stays the same?
See also Clifford parallel.
I believe the definition of "to be parallel" for geodesics in the context of non-euclidean geometry actually doesn't demand that the (minimum) distance between them must stay constant.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
  • · Replies 17 ·
  • · Replies 27 ·
  • · Replies 30 ·
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 58 ·
