Erik_clifton102
- 13
- 1
- TL;DR Summary
- Using TIP31C NPN transistor to amplify a current from 0A to 10A with 10V, but the transistor is over heating, max loads are 100V and up to 25A if I have read the data sheet correctly.
I have been trying to build a simple Current control circuit using a NPN TIP35C transistor but have run into the problem of it constantly over heating and being destroyed. The transistor is the only component that heats up whilst it is on. The supply voltage is 10V, well below the Max and at the moment I am only running a max of 7A through the transistor. If I have also done my calculations a am well below the power dissipation for the transistor.
what could I possibly be doing wrong or what have a missed? or do I just need a heat sink to dissipate the heat?
I have attached the Datasheet for the transistor below.
