Number of collisions; elastic collisions
The discussion centers on the number of elastic collisions between two masses and a wall, revealing a pattern where the number of collisions approximates values of Pi as the mass ratio increases. When the mass ratio m2/m1 is 1, there are 3 collisions; with a ratio of 100, there are 31 collisions, and with 100,000,000, there are approximately 31,415 collisions. The calculations provided include specific formulas for the velocities of the masses, indicating a regular denominator but a complex numerator. Clarification is sought on whether collisions with the wall count towards the total collision tally, which is confirmed to include all elastic collisions without friction. The discussion emphasizes the mathematical relationship between mass ratios and collision counts, linking it to the concept of Pi.
Gloyn
Hi!
I have found an interesting statement. It says, that if we have a system of two masses and a wall (all collisions will be elastic ones) with one mass (lets label it as 1) trapped between the other mass (2) and the wall and if there is no friction, then if ratio of masses m2/m1=1, then number of collisions between the masses will be 3, when m2/m1=100 then there will be 31 bounces, if m2/m1=100.000.000 then there will be 31415 collisions etc, the number of collisions will approximate more and more numbers in Pi. How do I explain it?
Conservation of momentum, Newton's Law of Restitution
I have calculated several velocities of masses to see if there is some simple rule. What I got is that the velocity of 2nd mass is:
V_1=v\cdot \frac{\alpha-1}{\alpha+1}
V_2=v\cdot \frac{\alpha^2+4\alpha-1}{(\alpha+1)^2}
V_3=v\cdot \frac{\alpha ^3 + 13\alpha^2+15\alpha-5}{(\alpha+1)^3}
So denominator seems to be fairly regular, but numerator is rather wild.
You have forgotten to specify the initial velocities of the masses. With some conditions, such as the outer mass having a velocity greater than that of the inner mass, and directed outside, there will not be any collisions.
We push the outer mass towards the inner, but velocity is not given, I just assumed it to be v. The inner mass is at rest before the first collision occurs.
Are collisions with the wall counted as collisions "between the masses"? I think they should be, otherwise you only get two collisions with equal masses.
Yes, of course, sorry for not being specific. I meant the total count of collisions. All are elastic, no friction between any objects whatsoever. And by alpha I denoted that outer mass is alpha times bigger than inner mass.
Here is the link to the full treatment of the problem by its author: http://ics.org.ru/doc?pdf=440
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
