Number of Molecules vs Velocity: Finding N for v > v_0
  • MHB
  • Thread starter alexmahone
  • Tags
    Molecules
In summary, the conversation discusses finding the number of molecules with a given velocity in a gas, using a graph with velocity on the x-axis and number of molecules on the y-axis. The conversation also mentions different ways of representing the data, such as a cumulative number plot and a histogram. The Maxwell-Boltzmann distribution, which describes the speed distribution of molecules in a gas, is also mentioned and used in the formula to calculate the number of molecules with a speed greater than a given velocity.
alexmahone
304
Suppose I have a graph with velocity of a gas v on the x-axis and number of molecules N on the y-axis, how would I find the number of molecules with v>v_0, where v_0 is a given velocity?
How about
$$\int_{v_{0}}^{\infty}N(v)\,dv?$$
Ackbach said:
How about
But that has dimensions vxN.
As stated, the answer to the problem is infinity since we have to consider infinitely many velocities. (Note that I have a continuous distribution.) So I guess we cannot have such a graph.
You're right about the units. I'll have to rethink that. However, you're not correct about infinities. What if $N(v)=e^{-v^{2}}?$ Note that $\int_{-\infty}^{\infty}N(v)\,dv=\sqrt{\pi}$, in that case. You can definitely have a finite integral, if the number of molecules with a given velocity drops off fast enough.
I have it, I think. Your function $N$ does not have units of [number of molecules]. It has units of [number of molecules]/[v]. So the [v]'s will cancel out in the integration. You're integrating a density function. So, I think that
$$\int_{v_{0}}^{\infty}N(v)\,dv$$
still works. And if your $N(v)$ is to be at all realistic, it must die off fast enough for the integral to converge, since we believe there are a finite number of molecules in the universe!
But I told you that N has units of [number of molecules]. With all due respect, N having units of [number of molecules]/[v] doesn't make any sense. Pretty sure you're mistaken.
On a continuous graph N cannot be a number it must be a number density.
CB
CB
What do you mean by number density?
If N is continuous then P[N=a] for any a is 0, so it can only be considered between a range of values.
As I understand the situation you are trying to create, the x-axis is continuous and the y-axis is discrete so for any $N_i$ there should be a corresponding range of velocities \(\displaystyle v_a<v_i<v_b=N_i\). However, N can't realistically be non-integer though unless molecule means something different than I've ever seen.
Number of molecule in a unit speed interval (or rather \( \lim_{\Delta v\to 0} N(v-\Delta v/2, v+\Delta v/2)/ \Delta v \) where \( N(v-\Delta v/2, v+\Delta v/2) \) denotes the number in the speed range \((v-\Delta v/2, v+\Delta v/2) \) )
CB
An alternative type of data presentation where the vertical scale is number is a cumulative number plot, where against speed v we plot the total number (or fraction) with speed less than or equal to v.
This gives a plot that is independedent of assumptions about discrete or continuous (or for that matter mixed continuous and discrete) distributions (one has steps, the other does not).
CB
The speed distribution of the molecules of a gas with absolute temperature T has been found by Maxwell and Boltzmann about hundred and fifty years ago...
$\displaystyle f(v)= \sqrt{\frac{2}{\pi}\ (\frac{m}{K\ T})^{3}}\ v^{2}\ e^{- \frac{m\ v^{2}}{2\ K\ T}}$ (1)
... where m is the mass of a single molecule and K is the 'Boltzmann's constant'. If N is the global number of molecules, the the number of molecules with $\displaystyle v> v_{0}$ is given by...
$\displaystyle N_{0}= N\ \int_{v_{0}}^{\infty} f(v)\ dv$ (2)
Kind regards
$\chi$ $\sigma$
Of course in the formula (2) You consider $N_{0}$ as continuous variable and is $\displaystyle N_{0}= N\ P \{v>v_{0}\}$. In case You intend to consider $N_{0}$ as an integer, then the x-y diagram must be an histogram where on the X axis is reported an integer k and on the Y axis is reported the number of molecules $N_{k}$ having speed $\displaystyle k\ v_{u} \le v< (k+1)\ v_{u}$. In this case the number of molecules having speed $\displaystyle > v_{0}$ is...
$\displaystyle N_{0}= \sum_{k= \text{int} \frac{v_{0}}{v_{u}}} ^ {\infty} N_{k}$
Kind regards
$\chi$ $\sigma$
FAQ: Number of Molecules vs Velocity: Finding N for v > v_0
What is the relationship between the number of molecules and velocity?
The relationship between the number of molecules and velocity is directly proportional. This means that as the velocity increases, the number of molecules also increases.
How do you calculate the number of molecules when the velocity is greater than v_0?
To calculate the number of molecules when the velocity is greater than v_0, you can use the formula N = n * V, where N is the number of molecules, n is the number density, and V is the volume of the gas.
What is the significance of finding N for v > v_0?
Finding N for v > v_0 is important in understanding the behavior of gases at high velocities. It can help in predicting the pressure, temperature, and other properties of the gas under these conditions.
What is the difference between number of molecules and number density?
The number of molecules refers to the total number of molecules present in a given volume of gas. On the other hand, the number density is the number of molecules per unit volume of the gas. In other words, it is the concentration of molecules in the gas.
How does the number of molecules change with increasing velocity?
As the velocity increases, the number of molecules also increases. This is because at higher velocities, the molecules are moving faster and therefore occupy more space. This results in a higher number density and thus a higher number of molecules in the same volume of gas.
