MHB Number of real roots in polynomial equation
  • Thread starter Thread starter juantheron
    Polynomial Roots
juantheron
Evaluate number of real roots of the equation $$x^6-x^5+x^4-x^3+x^2-x+\frac{2}{5} = 0$$
Mathematics news on Phys.org
My solution:
Let $$f(x)=x^6-x^5+x^4-x^3+x^2-x+\frac{2}{5}$$
And then:
$$f'(x)=6x^5-5x^4+4x^3-3x^2+2x-1$$
$$f''(x)=30x^4-20x^3+12x^2-6x+2$$
$$f'''(x)=120x^3-60x^2+24x-6$$
$$f^{(4)}(x)=360x^2-120x+24$$
The 4th derivative has a negative discriminant, therefore as an upward opening parabolic function, is positive for all $x$. This means the third derivative is strictly increasing and can have only 1 real root. Using a numeric root-finding technique, we find this root is approximated by:
$$x\approx0.342384094858369$$
We then look at:
$$f''(0.342384094858369)=0.961949707437654530>0$$
This means we may conclude that the 2nd derivative is positive for all $x$, and so the first derivative is strictly increasing with only 1 real root, which we find at about:
$$x\approx0.67033204760309682774$$
We then look at:
$$f(0.67033204760309682774)=0.03509389397174151671752$$
And so we conclude that for all real $x$, we have $f(x)>0$, and thus $f$ has no real roots.
Another way:
If $p(x)=x^6-x^5+x^4-x^3+x^2-x+\dfrac{2}{5}$ then $p(-x)=x^6+x^5+x^4+x^3+x^2+x+\dfrac{2}{5}$ and by the Descartes' Rule of Signs there are no negative roots for $p(x)$.
On the other hand, if $f(x)=a_nx^n+\ldots +a_1x+a_0\in\mathbb{R}[x]$ with $a_n\neq 0$ and $c$ a root of de $f(x)$ then $|c|\leq M$ where $$M=\max\left \{\left(n\left| \frac{a_{i-1}}{a_n}\right|\right)^{1/i}:i=1,\ldots,n\right\}.$$ Now, we can use the Sturm's Theorem on the closed interval $\left[0,\lfloor M\rfloor +1\right].$
My Solution::
$\bullet\; $ If $x\leq 0\;,$ Then $\displaystyle f(x) = x^6-x^5+x^4-x^3+x^2-x+\frac{2}{5}>0$
$\bullet\; $ If $x\geq 1\;,$ Then $\displaystyle f(x) = x^5(x-1)+x^3(x-1)+x(x-1)+\frac{2}{5}>0$
$\bullet \; 0<x<1\;,$ Let $\displaystyle f(x)-\frac{2}{5} = x^6-x^5+x^4-x^3+x^2-x=x(x-1)(x^4+x^2+1)$
So $\displaystyle f(x)-\frac{2}{5} = -x(1-x)(1+x+x^2)(1-x+x^2) = -(1-x^3)(x-x^2+x^3)$
So $\displaystyle -f(x)+\frac{2}{5} = (1-x^3)(x-x^2+x^3) \leq \left(\frac{1-x^3+x-x^2+x^3}{2}\right)^2$
So $\displaystyle -f(x)+\frac{2}{5}\leq \left(\frac{x-x^2+1}{2}\right)^2 = \frac{1}{64}\left(4x-4x^2+4\right)^2$
So $\displaystyle -f(x)+\frac{2}{5} \leq \frac{1}{64}\left(5-(2x-1)^2\right) \leq \frac{25}{64}$
So $\displaystyle -f(x)+\frac{2}{5}\leq \frac{25}{64}\Rightarrow f(x)-\frac{2}{5}\geq \frac{25}{64}$
So $\displaystyle f(x)\geq \frac{2}{5}-\frac{25}{64} = \frac{3}{320}>0$
So $\displaystyle f(x) = x^6-x^5+x^4-x^3+x^2-x+\frac{2}{5}>0\;\forall x \in \mathbb{R}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
