Number Patterns: 11,13,17,19,23,29,31,....?
  • Thread starter Thread starter lahirurana
    Patterns
The discussion revolves around identifying the next number in the pattern 11, 13, 17, 19, 23, 29, 31. Participants initially suggest 35 based on observed differences between consecutive numbers, but later realize the sequence relates to prime numbers. The correct next number is identified as 37, as the sequence consists of prime numbers. There is debate about whether this constitutes a sequence since no nth term equation is provided, but it is acknowledged that all sequences are patterns. Ultimately, the conversation highlights the nature of prime numbers and the potential for multiple interpretations of number patterns.
lahirurana
Moved form a technical forum, so homework template missing
Im little bit new to number patterns. Can anyone please solve this for me
11,13,17,19,23,29,31,?
This maybe pretty easy one but I am little bit confused.
What have you tried to do to solve it, so far ?
Different between consecutive numbers are 2 4 2 4 6 2
As my opinion next should be 4. So the answer should be 31+4=35
If the pattern go further it should be like 2 4 2 4 6 2 4 6 8 2 4 likewise. But the answe is given as 37
In my first attempt, I got the same number as you did. But looking at the numbers again, I realized that this is not a sequence based on a progression, but is related to an inherent property of the numbers (in other words, it has nothing to do with the difference or any other mathematical relation between two consecutive numbers). Hope this is a helpful hint.
Likes BvU and lahirurana
Ohhhh s*** How could i miss that. Thank you very much sir. Primary Numbers
Likes Nik_2213 and CWatters
If it's any consolation: I went for 35 too !
:welcome:
Likes lahirurana
There are more like this ill add them later. First i have to try something on them. thank you very much.
That shows that such problems can have multiple solutions. Unless a context is given, I see no reason why 35 wouldn't be a valid answer.
Likes lahirurana
Does that actually count as a "sequence" given there isn't an equation for the nth term?
I don't think that it can be take from nth term
The OP never used the term sequence, only pattern.
Likes CWatters and lahirurana
Yep All sequences are patterns but not all patterns will be squences
Likes jedishrfu
Good catch.
Likes Nik_2213
That is definitely a sequence. There is no such requirement that an equation is needed for the nth term.
I agree.
Likes SammyS
37 seemed to me to be the obvious next number in the sequence, for the reason that DrClaude gave.
lahirurana said:
Primary Numbers
We call them prime numbers in English.
And here's a formula for the whole sequence, starting with ##2,~3,~5,~7~...##
