Numerical analysis w/euler's method
solowa4
The amount of a uniform distributed radioactive contaminant contained in a closed reactor is measured by its concentration (c) (Becquerel/liter or Bq/L). The contaminant decreases at a decay rate proportional to its concentration; that is
Decay rate(dc/dt)= -kc
Where (dc/dt) is the change in mass, (k) is a constant with units of (day^-1), and (-kc) is the decrease by decay.
a-use euler's method to solve this eq from t=0 to 1 day with k=0.2 day^-1. Employ a step size of Delta t = 0.1 day. The concentration at t=0 is 10 Bq/L.
b-plot the solution on a semilog graph (ie (ln c) versus (t) and determine th slope.
I am at a loss at where to begin or accomplish this.
Welcome to PF!
Well, the first step is understanding how Euler's Method works. What do you know about it?
Not much as I just started the class :( That's why it is giving me difficult time
I have already looked at this and other sources with no help to my problem.
Thanks for your help
Sure it does. It explains the methodology:
y(n+1) = y(n) + h*y'(n)
t(n+1) = t(n) + h
For the Wiki example (i.e. y' = y and h = 1)
t(0) = 0, y(0) = 1, y'(0) = y(0) = 1
t(1) = 0 + 1 = 1, y(1) = y(0) + h*y'(0) = 1 + 1*1 = 2, y'(1) = y(1) = 2
t(2) = 1 + 1 = 2, y(2) = y(1) + h*y'(1) = 2 + 1*2 = 4, y'(2) = y(2) = 4
t(3) = 3 + 1 = 3, y(3) = y(2) + h*y'(2) = 4 + 1*4 = 8, y'(3) = y(3) = 8
In your case, you know that t(0) = 0, y(0) = 10, h = 0.1, and y' = -ky with known value for k.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
