A Numerically solving Scalar field coupled to Friedman equation
The discussion centers on numerically solving the Friedmann equation coupled to a scalar field, as detailed in the research paper by Sean Carroll and colleagues. The author, a physics graduate student, seeks assistance due to a lack of understanding and urgency to complete their degree. A response from one of the paper's authors clarifies that while the problem is standard, it requires careful rescaling of parameters and emphasizes that only equations 5 and 14 need to be solved together, as others are redundant. The author suggests using Mathematica for the numerical solution and provides a resource for further guidance. This exchange highlights the challenges of tackling complex equations in theoretical physics.
Soony143
TL;DR Summary
I am a research student of MS PHYSICS. I have to numerically solve Friedman equation coupled to scalar field(phi). It is given in research paper of Sean Carroll, Mark Trodden and Hoffman entitled as ""can the dark energy equation of state parameter w be less than-1?"" http://dx.doi.org/10.1103/PhysRevD.68.023509
The equations, that can be used are equation 5 and 14.
Plz someone help me, since it took me two extra semesters and I am on a verge of losing my degree, as per university policy.
Space news on Phys.org
I know 0 about this topic, however, I’d start by listing all boundary conditions and all symmetries the problem is expected to have. Every symmetry should allow you to reduce the complexity of the resulting differential equation. Hopefully this will greatly improve your chances for a numerical solution.
Will be a kind act.. thanks
Following is the reply i received from one of the author of the paper, when I requested him to help me
Hi,
I won’t be able to spend a lot of time on this but your question is not really about our paper. You’re asking about solving the Friedman equation coupled to a scalar field. This is a standard system that many authors have solved numerically It can be done in Mathematica, but one should rescale parameters so that one need not use large dimensionaful parameters like the Planck mass. Furthermore, you need not solve equation all three equations since they are redundant. Solving 5 and 14 together is sufficient.
Typically, the more difficult part of this is the Friedman equation, which is first order. You can find an example of how to approach solving it here
https://web.physics.ucsb.edu/~gravitybook/mathematica.html
You would need to include the scalar equation and solve them simultaneously.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
