Object moving in equilateral triangle - magnitude of acceleration
An object moves with a constant speed of 22.3 m/s around an equilateral triangle, completing the path in 12.69 seconds. The average acceleration vector's magnitude is calculated using vector components and relevant equations. The solution involves breaking down the motion into x and y components. The final calculated average acceleration is 3.04 m/s². This demonstrates the relationship between constant speed and changing direction in circular motion.
physos
An object moves around a equilateral triangle with a constant speed (magnitude of velocity is constant) of 22.3 m/s. If it moves from the starting to ending point (as shown below) in a time of 12.69 seconds, what is the magnitude of the average acceleration vector in m/s2?
V\DeltaV= (rFx-rix/delta(t)) - (rfy-riy\delta (t))
Break the vector into x and y components then use the equation:
(delta)y=v0t-(1/2)gt^2
Thanks! i figured out the answer.. its 3.04
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
