B Observers sending signals to measure expansion
The discussion centers on the concept of cosmic expansion and its observability between two observers. The current expansion rate is clarified as 73.3 km/s per megaparsec (Mpc), meaning the expansion speed increases with distance. Observers must be in a region of space that is not gravitationally bound and has an average matter density similar to the universe to observe this expansion. A void is deemed unsuitable for observing expansion due to its lack of average density and curvature. Ultimately, cosmological behavior is an emergent phenomenon that does not manifest at smaller scales, although the cosmological constant can influence behavior across all scales.
BWV
TL;DR Summary
Help me understand expansion rate
Googling you find a current expansion rate of ~70 km/s or 0.0002C but of course we don't observe this with objects in the solar system as local gravity prevents this expansion - otherwise a distances would increase by a light second roughly every 71 minutes (maybe I’m missing some here conceptually?)
question is - how far apart would to observers sending signals to one another need to be in order to observe expansion? (assuming they could wait however long it took to send and receive the signal) - between here and Andromeda (after accounting for the trajectories of the two galaxies) or farther?
what about two observers floating in some intergalactic void - could they observe expansion at relatively small distances?
Space news on Phys.org
This is not correct. You have specified a SPEED, not an expansion rate. The expansion rate is 73.3 km/s/Mpc. That is, the expansion SPEED is a function of distance. At 1 Mpc, it IS 73.3km/s but at 2Mpc it's 146.6km/s and at 3Mpc ... etc.
Also, whether or not expansion is happening in a given area of space is a function of what's IN that space. For bound systems, whether very large galactic clusters or a single non-clustered galaxy, it doesn't happen inside the cluster or galaxy but how far away it starts to occur will depend on how close something has to be to still be bound to the galaxy or the cluster.
SO ... there is no hard and fast numerical answer to your question.
thanks - so simply per above 2 observers 1 mpc apart floating in a much larger intergalactic void would observe their signals taking longer to send and receive proportional to space expanding at 73 km/s and the 6.5 million years for the round-trip signal?
I believe so, yes.
Actually, a void isn't what you would want to observe this. A void would not be governed by the overall universe geometry (aside: advanced technical terms: the void would have pure Weyl curvature, while the FLRW geometry is pure Ricci curvature. Expansion is a feature of Ricci curvature and initial conditions. Ricci curvature requires a distribution of matter and/or energy). What you would want is a is large enough region to be not gravitationally bound, with average matter and energy density similar to the universe as a whole. And you would want the initial state of the observers to be not just any free fall trajectory, but ones consistent with the so called Hubble flow. Then you should observe the effect you describe.
What also might work is a 1 Mpc region filled with average matter/energy density embedded in a 'typical' region between galactic clusters. But I'm not sure this would really work if the region around this 1 mpc region is of substantially below average matter/energy density. So the only sure fire case is as above - effectively a typical region larger than a galactic cluster.
[edit: sorry, this is not really a B level answer, but I can find no simpler way to describe it without being substantially inaccurate]
Likes PeterDonis, berkeman, phinds and 1 other person
A perhaps useful analogy is the think about the surface of a golf ball. The general features of the cosmology (cosmological redshift, Hubble 'constant', expansion etc.) correspond to the overall average spherical geometry of the golf ball surface. This overall spherical character is irrelevant to the geometry of a region of a few dimples. Thus, cosmological behavior simply doesn't exist at smaller scales. And, stretching the analogy a bit, a void would be like taking a slice off a bit of the golf ball, leaving a flat region. This would thus have none of the overall spherical large scale average geometry.
Summary: cosmological behavior is large scale emergent behavior. It has no small scale consequences at all (contrary to a great many misleading suggestions that it does).
[edit: I forgot one key exception: the cosmological constant. To the extent that GR with a cosmological constant is correct, the cosmological constant influences behavior at all scales. However, this has nothing to do with applying the scale factor in FLRW metric at local scales, or even applying large scale curvature locally. It does mean, in principle, that orbits should be calculated using the cosmological constant version of Schwarzschild geometry. The effects of this, of course, are many many orders of magnitude less than what is observable, so no one does this. Recall how small the cosmological constant is for our universe in the reference model. ]
Likes phinds and BWV
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
