Obtaining the matter Lagrangian from the stress energy tensor
In summary, the process of obtaining the matter Lagrangian from the stress-energy tensor involves using the relationship between these two quantities in the context of field theory and general relativity. The stress-energy tensor encapsulates the distribution and flow of energy and momentum in spacetime, while the Lagrangian density describes the dynamics of a system. By applying the principle of least action and utilizing the equations of motion, one can derive the matter Lagrangian that corresponds to a given stress-energy tensor, thereby linking the microscopic properties of matter to its macroscopic effects in spacetime.
Bishal Banjara
90
TL;DR Summary
Generally, the Stress energy tensor is obtained from the Lagrangian. But is it possible to obtain matter Lagrangian (Lm) from the Stress energy tensor?
Basically, the stress energy tensor is given by $$T_{uv}=-2\frac{\partial (L\sqrt{-g})}{\partial g^{uv}}\frac{1}{\sqrt{-g}}.$$ It makes easy to calculate stress energy tensor if the variation of Lagrangian with the metric tensor is known. But it is possible to retrieve matter Lagrangian if the stress energy tensor is known? Is one of the possible way to solve is taking the integration of the above equation?
[Moderator's note: Some off topic content has been deleted.]
I think you are supposed to take the variation of the lagrangian with respect to the metric. But I think you can derive the Lagrangian density from the Einstein Hilbert action which is a functional of the metric tensor and Ricci scalar. The Ricci scalar can be calculated directly from the stress-energy tensor if you know the metric.
Likes Bishal Banjara
Yes, that's correct. That's what the equation in the OP describes.
The "Einstein-Hilbert action" is the Lagrangian density (technically the "action" is the integral over spacetime of the Lagrangian density, but that just means you read off the Lagrangian density from the integrand; there's no "derive" needed).
Yes.
You don't even need the stress-energy tensor; the Ricci scalar is a function of the metric and its derivatives.
As @dsaun777 points out, that equation is for the variation of the Lagrangian density with respect to the metric. That is not the same thing as a derivative and so the equation cannot be integrated the way you are thinking.
If this is solved, rest is simple.
As far as obtaining the stress-energy tensor from the Lagrangian, yes.
But in the OP you are asking about obtaining the Lagrangian from the stress-energy tensor. See post #4.
I know the metric, then what is the mathematical relation between the Ricci scalar and stress energy tensor?
Yes, I am asking to retrieve the case. But if there is way to explore the variation of matter Lagrangian density with metric tensor resolving the variation, then don't this makes sense to solve the problem?
That was my mistake that I apparently saw partial differentiation in my own post. It is even mistake at this time also, please make it as variation. I have no edit option.
The Einstein Field Equation relates the Ricci tensor, Ricci scalar, and stress-energy tensor.
What you are describing here is, again, deriving the stress-energy tensor from the Lagrangian using the variational method. If you use the full Lagrangian (including the Einstein-Hilbert term as well as the matter Lagrangian), the variational method just gives you the Einstein Field Equation. That has been known since 1915, when Hilbert published his derivation of the EFE by this method.
However, the "problem" that you say you are trying to solve is going in reverse--start with the stress-energy tensor and figure out what Lagrangian it came from by "integrating" the variational equation. But the variational equation is not a differential equation and can't be integrated that way.
Likes vanhees71
I followed the reverse back derivation of $$T_{\mu\nu}$$ in the equation $$T_{\mu\nu}=\frac{2\delta(\sqrt{-g}\mathcal{L}_m)}{\sqrt{-g}\delta{g^{\mu\nu}}}$$ multiplying by $$\sqrt{-g}/2$$ and reintroducing the intergand. Further, we get variation of matter action as $$\delta{S_M}=\dfrac12\int{T_{\mu\nu}\sqrt{-g}d^4x\delta{g^{\mu\nu}}}$$.This would lead to the expression of matter Lagrangian density as $$L_m=\dfrac12\int{T\sqrt{-g}d^3x}$$ where $T$ is trace stress energy tensor. This follows the lagrangian density $$\mathcal{L}_m =\dfrac T2$$ where, $T$ is obtained by contraction with $$g^{\mu\nu}$$. In terms of $$T_{\mu\nu}$$, we could extend this equation as $$\mathcal{L}_m=\dfrac12g^{\mu\nu}T_{\mu\nu}$$.
Is it correct?
Correction: This would lead to the expression of matter Lagrangian (not density) as
FAQ: Obtaining the matter Lagrangian from the stress energy tensor
What is the matter Lagrangian in the context of the stress-energy tensor?
The matter Lagrangian, often denoted as Lm, is a function that describes the dynamics of matter fields in a given physical theory. It serves as the starting point for deriving the stress-energy tensor, which encapsulates the distribution and flow of energy and momentum in spacetime.
How is the stress-energy tensor derived from the matter Lagrangian?
The stress-energy tensor Tμν is derived from the matter Lagrangian by varying the action with respect to the metric tensor gμν. Mathematically, this is expressed as Tμν = -2 / √(-g) * δ(√(-g) Lm) / δgμν, where g is the determinant of the metric tensor.
What role does the stress-energy tensor play in general relativity?
In general relativity, the stress-energy tensor acts as the source term in the Einstein field equations, which describe how matter and energy influence the curvature of spacetime. The equations are given by Gμν = 8πG Tμν, where Gμν is the Einstein tensor and G is the gravitational constant.
Can the matter Lagrangian be uniquely determined from the stress-energy tensor?
In general, the matter Lagrangian cannot be uniquely determined from the stress-energy tensor alone. This is because different Lagrangians can yield the same stress-energy tensor when varied with respect to the metric. Additional information or constraints are usually necessary to uniquely specify the matter Lagrangian.
What are some common examples of matter Lagrangians used in physics?
Some common examples of matter Lagrangians include the Lagrangian for a scalar field φ, given by Lm = ½(∂μφ ∂μφ - m²φ²), and the Lagrangian for an electromagnetic field, given by Lm = -¼ FμνFμν, where Fμν is the electromagnetic field tensor. These Lagrang
