Appliances Ohm readings on a 3 prong clothes dryer
  • Thread starter Thread starter Stephen Tashi
Typical resistance readings across the prongs of a 3-prong clothes dryer plug when unplugged can vary. Open circuits are expected between the two hot prongs and between the neutral and one hot prong. However, a reading of 127 ohms between the neutral and the other hot prong may indicate a power supply characteristic, as similar measurements on a working dryer showed 17 K ohms, dropping to 2 ohms when the start button was pressed. This suggests a standby power supply with inductive components. Without mains voltage, resistance readings can be unpredictable. It is crucial to ensure the circuit breaker rating is adequate before plugging in the dryer. Additionally, when transitioning from a 3-prong to a 4-prong outlet, it is important to address grounding issues, as using the neutral as a ground is not permitted in many jurisdictions. Consulting an electrician to install a 4-conductor cord and make necessary internal wiring adjustments is recommended for safety compliance.
Stephen Tashi
Homework Helper
Education Advisor
TL;DR Summary
What are the typical ohm readings across the prongs of a plug on an unplugged 3-prong clothes dryer?
What are the typical ohm readings across the prongs of a plug on an unplugged 3-prong clothes dryer? - if such typical values exist.
I bought a used electric clothes dryer (Maytag Model MEDP576KW1 ) that I haven't plugged in yet. The seller is a reliable local business that says it works. When I measure the resistance between pairs of prongs on the cord, I get, as expected, an open circuit between the two hots and between the neutral and one of the hots. But the resistance between the neutral and the other hot is 127 ohms. This doesn't change when I fiddle with the controls on the dryer.
I took similar measurements on a working dryer that I unplugged. I get the same open circuits. Between the neutral and one of the hots, I get 17 K ohms. When I press the start button, it drops to 2 ohms.
127 ohms would be expected across a power supply, before it starts.
17k ohms, dropping to 2 ohms, is a standby power supply, with an inductive fan or motor being connected when switched on.
Without mains voltage being applied to the appliance, it is unpredictable what resistance to expect. Check the circuit breaker rating for the outlet is sufficient, plug it in and switch it on, with a little caution.
Likes Stephen Tashi and berkeman
I will as soon as I solve another problem - the power cord on the dryer is 3-prong and the receptacle for it is 4-prong. I debate whether to change the receptacle and leave its ground unconnected or whether to change the cord on the dryer. The dryer was not designed for a 4-wire cord, but it looks possible to ground it. My readings find only one connection point between the neutral and the chassis. It is at the terminal (temporarily disconnected) on the left in the photo
. The terminal is on the end of a white wire that is part of the dryer's wiring, not part of the cord.
See page 7 of the installation manual at:
https://www.maytag.com/content/dam/.../installation-instructions-w11407405-reva.pdf
The existing wiring with the 3-conductor cord uses the Neutral of the 120/240V supply for a Safety Earth Ground. As a potential safety hazard,
THIS IS NOT ALLOWED IN MANY JURISDICTIONS.
The existence of a 4-prong outlet suggests you are in one of those jurisdictions.
Please get an electrician to install a 4-conductor cord/plug, and show him the manual page 7 for required internal wiring changes.
Cheers,
Tom
Likes pbuk, berkeman and Stephen Tashi
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
