- 11,308
- 8,736
anorlunda submitted a new PF Insights post
Ohm's Law Mellow
Continue reading the Original PF Insights Post.
Ohm's Law Mellow
The ideal gas law doesn't apply for real gases. Is the ideal gas law then not a law?
We can determine the speed, distance, or rate (MPH/KPH) by knowing 2 of the 3. But, we certainly do not say that the length of the road causes motion of the vehicle. I see it is really no different with ohms law.LvW said:...and we can think about the meaning of the form: V=I*R.
We are using this form to find the "voltage drop" caused by a current I that goes through the resistor R.
However, is it - physically spoken - correct to say that the current I is producing a voltage V across the resistor R ?
(Because an electrical field within the resistive body is a precondition for a current I, is it not?)
LvW said:However, is it - physically spoken - correct to say that the current I is producing a voltage V across the resistor R ?
Yes. But Ohm's Law specifically refers to Metals at a constant temperature, doesn't it? Your point has been ignored by the contributions to this thread.vanhees71 said:The electric conductivity of course is a function of temperature and chemical potential (for an anisotropic material it's even a tensor).
sophiecentaur said:Yes. But Ohm's Law specifically refers to Metals at a constant temperature, doesn't it? Your point has been ignored by the contributions to this thread.
vanhees71 said:One should also mention that the Drude model is not the final answer but that the "electron theory of metals" is one of the first examples for a degenerate Fermi gas (Sommerfeld model). The model was extended by Sommerfeld, explaining the correct relation between electric and heat conductivity (Wiedemann-Franz law).
ZapperZ said:However, since the OP discussed the "non-derivable" issue, and did not even mention the Drude model, I consider that to be a significant omission.
anorlunda said:It sounds like you didn't read to the end. The article does mention the Dude model as one of five levels at which you can study electricity. It also says that the scope of the article was limited to circuit analysis.
LvW said:However, is it... correct to say that the current I is producing a voltage V across the resistor R ?
I disagree to the general Idea that Ohm's Law is not a law, yet I strongly support the importance of this issue which I think boils down to the very basics philosophy of what is a physical law, what are the therms under which it consider violated.anorlunda said:anorlunda submitted a new PF Insights post
Ohm's Law Mellow
I wholeheartedly agree. It's a formula / definition and says nothing about whether or not Ohm's law happens to apply to what's connected to the terminals on the 'black box' we're examining. R could change, or not as V,I or T changes. If it doesn't happen to change then the component is not following Ohm's Law. But one calculation wouldn't tell you one way or the other.anorlunda said:I view the definition of R as the ratio of V and I. As a definition, it can't be violated by definition (pun intended )
vanhees71 said:Ohm's Law is derived from many-body theory. It's defining a typical transport coefficient in the sense of linear-response theory. It's the "answer" of the medium to applying an electromagnetic field, and defines the electric conductivity in terms of the induced current, ##\vec{j}=\sigma \vec{E}##, where in general ##\sigma## is a tensor and depends on the frequency of the applied field. So Ohm's Law is a derived law and has its limit of validity (particularly the strength of the electromagnetic field must not be too large in order to stay in the regime of linear-response theory).
That's ramping it up a bit for a number of the audience, I think. But also, if σ changes with some other variable, the relationship breaks down so any 'Law' has hit the rails. A Law that's worth its salt will involve all the relevant variables - Ohm's law, when stated fully, fits that requirement.vanhees71 said:Ohm's Law is derived from many-body theory. It's defining a typical transport coefficient in the sense of linear-response theory. It's the "answer" of the medium to applying an electromagnetic field, and defines the electric conductivity in terms of the induced current, ##\vec{j}=\sigma \vec{E}##, where in general ##\sigma## is a tensor and depends on the frequency of the applied field. So Ohm's Law is a derived law and has its limit of validity (particularly the strength of the electromagnetic field must not be too large in order to stay in the regime of linear-response theory).
It's true for any medium in the linear-response regime. More completely written out the relation readsanorlunda said:That's true for the specialized case of a linear and uniform mediums. The article addresses the general case of circuits containing any components, linear/nonlinear, active/passive. As the article says, you can always linearize about a point, define R=V/I, then use linear circuit methods to solve it.
I don't know, what you mean. Electric conductivity is a typical transport coefficient, describing the response of the medium to a small perturbation around equilibrium (in this case by a weak electromagnetic field). It's restricted to weak fields in order to stay in the linear-response regime. Of course, it has a range of validity, as has any physical law (except the ones we call "fundamental", because we don't know the validity ranges yet ;-)).sophiecentaur said:That's ramping it up a bit for a number of the audience, I think. But also, if σ changes with some other variable, the relationship breaks down so any 'Law' has hit the rails. A Law that's worth its salt will involve all the relevant variables - Ohm's law, when stated fully, fits that requirement.
I just meant that your wording and representation takes it to a higher level of understanding and familiarity. Of course the equation is correct - but it doesn't pretend to be a Law. By the time one gets to the level that you are using to describe what happens, I doubt that one would bring in the term Law.vanhees71 said:I don't know, what you mean. Electric conductivity is a typical transport coefficient, describing the response of the medium to a small perturbation around equilibrium (in this case by a weak electromagnetic field). It's restricted to weak fields in order to stay in the linear-response regime. Of course, it has a range of validity, as has any physical law (except the ones we call "fundamental", because we don't know the validity ranges yet ;-)).
Isn't that just a chicken and egg argument for describing a 'relationship' between two variables?David Lewis said:Yes, if it's an applied voltage. A voltage drop (symbol V) occurs when current passes through the resistor.
Conversely, with a voltage source, EMF (symbol E) produces the current that passes through the resistor.
