Which Solar Setup is Best for a Zero-Feed Tariff Family Home?
In summary: AC because you're only using solar during the day). Solar panels generate DC power, which needs to be converted to AC power by an inverter. An AC outlet is more versatile than a DC outlet, so it makes more sense to use AC. I would choose Option 1) because it has the MPP tracker included, which makes it more accurate. I would choose Option 1) because it has the MPP tracker included, which makes it more accurate.
says
594
For an economical PV system, with zero-feed in tariff, for a family home, with no one at home during the day time, the best setup option would be:
(some components might be in another)
1) PV, batteries, charge controller, inverter
2) PV, MPP tracker, batteries, charge controller, inverter
3) PV, MPP tracker, batteries, charge controller, inverter, generator
4) PV, MPP tracker, charge controller, inverter
5) PV, MPP tracker, inverter, generator
I think the components being in another would be the MPP tracker being in the inverter. The system has zero-feed in tariff, but it's tied to the grid.
These were the 5 options I was given. I would use PV, MPP tracker, inverter and generator.
If the system is tied to the grid anything with batteries seems like a waste. That leaves only option 4) and 5). Option 4) has a charge controller, which is used to limit the amount of current flowing into and out of a battery, and there is no battery in Option 4), so I wouldn't choose that one either.
I'm not sure what a zero-feed tariff is, but if it means you don't get paid for electricity fed into the grid, why would you do it?
Surely it would be better to use it to drive permanent loads like fridges, air conditioners and heating, then save any balance until you come home. In which case, wouldn't you need the battery?
I assumed zero-feed in tarrif means the energy company isn't buying back the electricity you generate.
I guess that during the day all this electricity is going to waste. So I agree -- I think it would be better to have batteries. In that case you would need a charge controller as well, so option 1) 2) and 3) sound better.
I guess what it comes down to now is if a generator is needed, and if the MPP tracker is in the inverter.
I assumed when they put MPP tracker and inverter, they mean to have both functions, whether they are in the same unit or separate, but if they say only inverter, they mean an inverter with no MPP tracker. Inverter seems to be assumed in all options, so it's just a question of whether you want the MPP tracker function or not.
What is the purpose of the generator?
The generator is used if there is power loss (PV stops working). But if you are tied to the grid then the grid acts as the generator I guess, so the generator isn't needed. So only Option 1) and 2) looked like the best ones.
There was a supplementary note in the question that said "Some components might be inside one product"
Solar inverters use MPP tracking to get maximum power of the PV system, so I would say Option 1) is the best answer.
You say MPP tracking gets the max power from the PV, but you choose an option without it? Is that to save cost?
BTW are you sure that MPP tracking is part of the inverter?
I think the reasons for some choices vary with climate, insolation, and your base system requirements.
For example, if you live in the Southwest and turned off power all day long: with no cooling temperatures in the house could become close to unbearable, same problem with a heat pump in Maine or Northern Michigan and pipes or well heads freezing.
Factor in appliances. Then there is really no complete "down time" for electric consumption in a modern house.
In other words, you may believe your peak consumption is when everyone is home with lights on. Maybe. Consider: Generally there are winter peak consumption hours tied to ambient conditions, same is true for summer. They may not coincide.
I choose an option without MPP tracking because the question said some components may be inside another.
I find the question's answers rather obtuse. Both Option 1) and 2) are correct, but solar inverters use MPP tracking, so Option 1) is MORE correct.
Well, I doubted that (that the MPP tracker is normally included in the inverter rather than another component.) But if you are saying you are going to use MPP tracking which you think is part of the inverter, then I think you should choose an option where MPP tracking is included. For me, an option where it says inverter but does not say MPP, would mean it was not using MPP tracking at all. There are plenty of inverters that certainly do not include MPP. But it's your question.
Perhaps it would help to think about the chain of processes and where each component fits in?
I agree with Jim's point, which is why I listed AC and CH (though I'd not thought specifically about heat pumps.) But, either you generate excess power at some part of some days, or you don't. If you never generate excess power, fair enough you'll never want a battery, but the question becomes a bit limited on that assumption - 1 to 4 all have batteries. If you may sometimes have excess power, then you need to decide what to do with it and how.
This source says solar inverters use MPP tracking: https://en.wikipedia.org/wiki/Solar_inverter#Maximum_power_point_tracking
There is excess power in the day not being consumed, so using a battery would be a better option. A generator doesn't seem like a good option though because you are tied to the grid. The grid can work as the generator if the PV isn't working.
I think it is really hard to answer the OP question without defining what you mean by economic.
IMO, your list has a glaring omission -- energy conservation. Besides writing checks for more equipment, are you willing to cut your energy consumption via life style choices? Could you halve the number of square feet needed for housing? Could you relocate to a place with lower climate control demands, or could you simply live with broader extremes of temperature?
Forgive me for being negative, but I see too many fellow Americans saying, "I want to be more green. Just tell me how big a check to write to whom." That approach is fundamentally flawed.
Let's go with 'economic = being the most cost effective.'
As I say, it's your choice. If I wanted to use an MPP function, I'd choose an answer which included MPP. They all use inverters, so why specify MPP in 4 of them and not in the other? I think they are giving the list of functions, not a list of boxes. For a commercial system it is likely that all electronic processing is in one unit.
In that case, the answer should be to cut your energy consumption. That's far more economic than those other options.
Of these 5 options:
1 or 2 is the most cost effective, no?
With no subsidy?
6) on grid: grid only
off grid: generator only
Related to Which Solar Setup is Best for a Zero-Feed Tariff Family Home?
1. What is the difference between on-grid and off-grid solar systems?
On-grid solar systems are connected to the electrical grid, meaning they can send excess energy back to the grid and receive energy from the grid when needed. Off-grid solar systems are not connected to the grid and rely solely on stored energy in batteries.
2. Which type of solar system is more cost-effective?
In general, on-grid solar systems tend to be more cost-effective since they do not require the additional expense of batteries and can take advantage of net metering, where excess energy sent back to the grid is credited to the homeowner's electricity bill.
3. Can on-grid solar systems still work during a power outage?
No, on-grid solar systems are designed to automatically shut off during a power outage for safety reasons. This is to prevent any excess energy from being sent back to the grid and causing harm to utility workers trying to restore power.
4. Are there any advantages to choosing an off-grid solar system?
Off-grid solar systems provide energy independence and can be a good option for remote or rural areas without access to the grid. They also do not rely on the grid, so they are not affected by power outages.
5. How do I determine the right size for my solar system?
The size of your solar system will depend on your energy needs, location, and budget. It is recommended to consult with a solar installer to assess your energy usage and design a system that meets your needs and budget.
  • Electrical Engineering
9K
10K
