- #71
jim hardy
Dearly Missed
- 9,832
- 4,896
BernieM said:The only possible way I can reconcile this is either it has to do with the chemical reactions that do or can take place in a battery (perhaps something that can happen when a cell has a certain type of failure?) or that my meter was not reading properly for some odd reason (bad meter, bad leads, poor connection?) when I connected it between the two batteries in series.
yeah, sounds to me like something opened up on ya.
I've had batteries break an internal connection. One car wouldn't start unless i pushed down on the post to make the internal connection again. It'd work the dome light and radio i guess through electrolyte but voltage collapsed with even the windshield wipers turned on.
We learn a lot in troubleshooting, among the most valuable is how little we know. I had to refresh my battery chemistry to keep up with this thread.
Here goes
a battery cell has two plates one of pure lead and the other of lead oxide. They are immersed in sulfuric acid which is a mix of hydrogen ions and sulfate ions.
The pure lead plate is the negative one
the lead oxide plate is the positive one
As the battery discharges,
the lead plate turns into lead sulfate and pushes electrons out into the external circuit,
the lead oxide plate .turns into lead sulfate and pulls electrons in from the external circuit
no electrons get 'stored' or hide out inside the battery
Here's pictures from http://ecee.colorado.edu/ecen4517/materials/Battery.pdf
that i annotated a little bit
that allows pure lead there to become lead sulfate and push electrons out into the world.
And over at the positive plate, almost instantaneously,
two electrons (but not the same two) enter from external circuit per Kirchoff's Current Law.
That allows the positive plate to pull electrons in from the outside world.
Were electrons allowed to accumulate or deplete inside the battery it would soon have an excess or shortage of them and rise to lightning-bolt potential with respect to its surroundings. That's how lightning works in clouds.
Sulfate ions in solution get replaced by water molecules. Electron balance is maintained.
Of course for charging just revere the directionsold jim
