- 5,941
- 3,120
The monochromatic sources of the visible spectrum make a horseshoe around the border of the CIE chart. We can get any point in the interior with a couple of points from this outside ring in the right combination. In the OP, I happened to pick a couple of points that lie on the straight line of the upper right portion of the outer ring, but that was completely by chance. It was only after I wrote the OP, around post 20 and after, that I figured out some of the details of the CIE chart, including the mathematics upon which it is based.sophiecentaur said:Can you apply your personal theory to explain how we see all those non-spectral colours that lie between the straight portion of the CIE chart and the central White Point? Nothing spectral in that area.
I do not think my inputs fall into the category of "personal theory". I'm simply taking what is there, and explaining it in very simple terms. Cheers. :)
Edit: and note that even broadband sources are represented by a single point on the CIE chart. With TV screens, if they can get 3 sources that have points sort of spread out around the horseshoe of the CIE chart, they can the cover anything inside the triangle that has vertices at these 3 points, so they can cover most of the interior of the CIE color map. They find the combination of a red source, a green source, and a blue source, even with each being somewhat broadband, works very well.
