On (pentagon shaped) electric field question.
The discussion revolves around calculating the electric field at the center of a regular pentagon with charges placed at its corners. The electric field equation E=q/(4∏ε0)(a^2) is mentioned, but the contributor suggests that simply summing the fields from the four corners is insufficient due to the pentagon's symmetry. They propose that the electric fields from the charges must be resolved into components to accurately determine the net electric field. The importance of symmetry in simplifying the calculations is emphasized, and the contributor refers to a diagram hosted on their blog for clarity. Ultimately, understanding vector decomposition is crucial for solving the problem effectively.
physikamateur
Four particles, each having a charge q are placed on the four corners A, B, C, D of a regular pentagon ABCDE. The distance of each corner from the centre is a. Find the electric field at the centre of the pentagon.
E=q/(4∏ε0)(a^2) where k=1/4∏ε0
Well certainly I think it's silly to just sum up four electric fields to give 4q/(4∏ε0)(a^2). I think it would seem obvious that there is a net electric field as shown in the attached diagram. Suppose E(E) exists. Then E(A)+E(B)+E(C)+E(D)+E(E)=0. My working is shown in the diagram attached. At the same time I am confused as how the electric field vectors resolves.
Darn, can't upload the diagrams. I've uploaded it on my random blog. Go to www.kcsuploads.blogspot.com and see pentagon diagram. Sorry for any inconvenience caused
Just add the vectors the way vectors add. Decompose them into their components in a convenient reference frame. Symmetry considerations will help set that up.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
