I On two definitions of locally compact
  • I
  • Thread starter Thread starter psie
    Topology
psie
TL;DR Summary
I've come across two definitions of local compactness. One author seems to equate these definitions and I wonder if they are actually equivalent, and if not, if it has any consequences?
I have a hard time accepting definitions that are inequivalent. So the main point of my post is to ask for confirmation that it does not matter having inequivalent definitions, but I'm not sure about this. Maybe these two definitions being inequivalent actually have some consequences.
First, there are two common definitions of a neighborhood:
Defintion 1 For ##x \in X##, ##V \subset X## is a neighborhood of ##x## if ##x \in U \subset V## for some open set ##U \subset X##. [e.g. Gamelin and Greene]
Definition 2 For ##x \in X##, ##V \subset X## is a neighborhood of ##x## if ##x \in V## and ##V## is open. [e.g. Munkres]
Now, here's the following definition of locally compact which I've come across in Topology: An Invitation by Parthasarathy (who uses definition 1):
Definition 3 A topological space ##X## is said to be locally compact if every point ##x\in X## has a compact neighborhood; i.e. there is an open set ##V## such that ##x\in V## and ##\overline{V}## is compact.
I don't follow how every point having a compact neighborhood is equivalent to there is an open set that contains the point whose closure is compact. When I read definition 3 I interpret the "i.e." as equating these two statements, but are they equivalent? If not, does it matter?
The first part of Definition 3 does not specify that the neighbourhood is open, so the second part is incorrect.
Hmm, I don't think I understand you.
  1. The first part of definition 3 specifies that the neighborhood be compact, i.e. that there is a compact set ##V\subset X## such that it contains an open set ##U\subset X## that contains ##x##.
  2. The second part of definition 3 specifies simply that there is an open set ##U## that contains ##x## and ##V=\overline{U}## is compact.
When I look at these two statements, statement 2 certainly satisfies the definition 1 of a (compact) neighborhood (so statement 2 implies statement 1). But I can not work out how statement 1 implies statement 2.
A compact neighborhood of ##x## means a compact set ##K## such that ##x## is contained in the interior of ##K##.
a closed subset of a compact set is compact. hence if V is a compact neighborhood of x, then the interior U of V is open and contains x, and the closure of U is a closed subset of the compact set V, at least when the space is Hausdorff. But since a compact set need not be closed in a non Hausdorff space, I don't see how the first part of the definition implies the second, in general.
compare: https://en.wikipedia.org/wiki/Locally_compact_space
Likes psie and martinbn
This is a good point! The closure of the interior of a closed set need not be the closed set itself.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
