- #36
- 14,391
- 6,878
Does it mean that locality is wrong? Or that realism is wrong? Or that both are wrong? What's your hunch?vanhees71 said:Q(F)T is correct, and local realistic theories are wrong.
Here I think TP is confused, because, if we would ask...Demystifier said:R: But the world is made of something, irrespective of whether we measure it or not. The measurement disturbs its behavior, but the stuff it is made of is the same, whether we measure it or not. Would you agree?
TP: Yes, that's probably true.
R: So you don't care about the stuff the world is made of.
TP: True, because it's a philosophical question.
This dialog only confirms what I said earlier. You mix notions. Already the first answer is meaningless.Demystifier said:Only to the point. To demonstrate this, let me present a typical dialogue between a "realist" (R) and a "typical physicist" (TP) how I see them.
No, it is not. It doesn't even make sense to say that the electron is the same as its wave function. You are identifying the territory and the map, and they are not the same things.Demystifier said:TP: The world is made of atoms, which are made of finer objects such as protons, neutrons and electrons.
R: Sure, but what these objects are? For example the electron, is it the same thing as its wave function?
TP: To the best of our knowledge, yes, the electron is nothing else but a wave function.
Let me quote myself:vanhees71 said:Since relativistic QFT in its standard form is based on locality (for causality reasons) it's "realism" that's wrong. Under "realism" I understand that all observables take determined values, and this is obviously wrong in all types of QT.
So I disagree. You talk about realism as if it must be about the classical point-like properties. But if we accept that reality consists of wavefunctions, that is totally unharmed by the Bell tests.In the paper "A system's wave function is uniquely determined by its underlying physical state" [1] it is concluded based on free choice that interpreting the wavefunction as an objective reality is possible
Th link gives a paper on integration of tensor fields! And it doesn't seem related!Structure seeker said:Let me quote myself:
Not me, it's the TP who wrongly identifies the territory and the map.martinbn said:No, it is not. It doesn't even make sense to say that the electron is the same as its wave function. You are identifying the territory and the map, and they are not the same things.
But you put the words in his mouth!Demystifier said:Not me, it's the TP who wrongly identifies the territory and the map.
OK, let's try!martinbn said:I am not a physicist, let alone a typical one, but I am willing to have the conversation as the TP, and we can see where it leads.
So my answer to the first question would be: "No, the electron is not the same as its wave function."
The words I put in his mouth represent his actual words. The words I put are the map, while his true words are the territory.martinbn said:But you put the words in his mouth!
The wave function represents the state of the electron. Other mathematical objects, for example some operators, represent the observables.Demystifier said:OK, let's try!
R: But wave function represents some properties of the electron. Is there another mathematical object that represents electron properties more directly than the wave function?
Can you quote the exact words and say whe they belong to?Demystifier said:The words I put in his mouth represent his actual words. The words I put are the map, while his true words are the territory.
Which of those, the state or the observables, changes with time? Is that change described by a deterministic equation?martinbn said:The wave function represents the state of the electron. Other mathematical objects, for example some operators, represent the observables.
Are you changing the subject? You know the answers. There is no disagreement between R and TP on this. Most importantly how is this related to ontology?Demystifier said:Which of those, the state or the observables, changes with time? Is that change described by a deterministic equation?
Please answer the question, you will see soon how this is related to ontology. I just need that YOU explicitly say that (even if I know it), so that you cannot later say that you didn't say it.martinbn said:Are you changing the subject? You know the answers. There is no disagreement between R and TP on this. Most importantly how is this related to ontology?
Ok, fine. In the Heisenberg picture the observables depend on time and satisfy the Heisenberg equations.Demystifier said:Please answer the question, you will see soon how this is related to ontology. I just need that YOU explicitly say that (even if I know it), so that you cannot later say that you didn't say it.
In relativistic QFT there are no wave functions but quantum fields.Structure seeker said:Let me quote myself:
In the Heisenberg picture the operators that represent observables in the QT formalism are time dependent and their time evolution is, by definition, governed by the full Hamiltonian. This is of little physical significance though since the physically meaningful quantities derived from the observable operators and the statistical operator are independent under arbitrary unitary transformations, which can be time dependent. In other words the physics is independent of the choice of the picture of time evolution.martinbn said:Ok, fine. In the Heisenberg picture the observables depend on time and satisfy the Heisenberg equations.
So where does quantum randomness come from?martinbn said:Ok, fine. In the Heisenberg picture the observables depend on time and satisfy the Heisenberg equations.
How does this relate to ontology! Now i have the feeling that you are just shooting in the dark hoping to hit something.Demystifier said:So where does quantum randomness come from?
I agree that a typical physicist would answer this question differently but I think the map-territory distinction becomes murkier as the concepts become more abstract.martinbn said:No, it is not. It doesn't even make sense to say that the electron is the same as its wave function. You are identifying the territory and the map, and they are not the same things.
You are misrepresenting the TP position. The difference between TP and R is not that R "cares" about ontology while TP does not, but that TP understands that at our current state of knowledge, we do not have good answers to ontological questions, and therefore does not see much point in continuing to beat one's head against the wall about them, while R refuses to admit this and keeps on asking the questions even though we do not have good answers to any of them. Understanding that we currently do not have good answers to certain questions is not at all the same as not "caring" about those questions at all.Demystifier said:let me present a typical dialogue between a "realist" (R) and a "typical physicist" (TP)
If you read the whole dialogue, you will notice that I said that. So I don't think that I misrepresent the TP.PeterDonis said:You are misrepresenting the TP position. ... TP understands that at our current state of knowledge, we do not have good answers to ontological questions, and therefore does not see much point in continuing to beat one's head against the wall about them,
I'm not, just be patient and we will come to that.martinbn said:How does this relate to ontology! Now i have the feeling that you are just shooting in the dark hoping to hit something.
From the Newton equation.vanhees71 said:Where does the determinism in classical physics come from?
You had TP say there are no good answers, yes. But that's by no means all you had TP say. You had TP say lots of other things that I don't think were appropriate for the TP viewpoint.Demystifier said:If you read the whole dialogue, you will notice that I said that.
I don't think these sorts of word games are appropriate here. If you have an argument to make, then make it.Demystifier said:I'm not, just be patient and we will come to that.
Assume i give the textbook asnwers to all your questions and get to thw point.Demystifier said:I'm not, just be patient and we will come to that.
R: So you do not care much about ontological questions, because there is no point in discussing them. Am I right?PeterDonis said:You had TP say there are no good answers, yes. But that's by no means all you had TP say. You had TP say lots of other things that I don't think were appropriate for the TP viewpoint.
What you should have had TP say was something like: "I know you feel compelled to ask these ontological questions. But we currently have no good answers to any of them. So what's the point of discussing them?"
How would you have R answer that?
TP: No. I have already said that admitting that we have no good answers to certain questions is not the same as not caring about them.Demystifier said:R: So you do not care much about ontological questions, because there is no point in discussing them. Am I right?
TP: The randomness is in the wave function collapse, which happens during the measurement.martinbn said:Assume i give the textbook asnwers to all your questions and get to thw point.
The Schrödinger equation then also implies that QM is deterministic.Demystifier said:From the Newton equation.
So why then QM is probabilistic in a way in which classical mechanics isn't? Where does the difference come from?vanhees71 said:The Schrödinger equation then also implies that QM is deterministic.
