Op-Amp basic problem with a LED diode
In summary, the voltage at the -input is +2V (based on the minus leg), so current through R1 is 1mA. The voltage at the output is 10V + 2V (based on the battery), so current through the LED is 5.3mA.
  • #71
The positive supply is always connected at the top of the op-amp, regardless of where the + and - inputs are.
Ah, really? That's kinda funny. Well, in that case
Vout = 7.8 [V]
The negative supply is always connected at the bottom of the op-amp.
[qupte]What is connected at the bottom of the op-amp?[/quote]
Well, V+ (what I defined it as) is connected to the bottom of the op-amp. Therefor -Vout = V+ = -5.526
  • #72
Vout = 7.8 [V]
Yes. That is true in case 1.
No, that is connected to the + input of the op-amp.
The negative power supply is specified to the right of that.
  • #73
I just realized something, I just need to find Vout in case 1 and case 2. Why did I do all those minuses and pluses for?
In both cases the Vout ways exceeds the limit of the op-amp. In fact, shouldn't the op-amp burn if that happens?
  • #74
Which minuses and pluses?
No, it just gets saturated and Vout is just either the positive or the negative power supply.
  • #75
I noticed I was trying to find -Vout and +Vout in the last few posts which doesn't make sense, since there is only 1 Vout in each of the 2 circumstances. I don't know why I did that. Must've gotten confused.
Gotcha.
Vout2 = V- = 6.3V
  • #76
Femme_physics said:
Vout2 = V- = 6.3V
Nooooo... there is an Earth symbol there. :rolleyes:
Shouldn't that be the negative power supply?
  • #77
Oh!
So, ok, taking the lower leg into consideration it's 7 - 5.526 = 1.474 [V]
  • #78
Femme_physics said:
Oh!
Huh? :confused:
Where did you get 7 V?
  • #79
Well, that's V3
  • #80
Femme_physics said:
Well, that's V3
But... V3 is not connected to the op-amp.
Before you had already the proper V+ and V-...
  • #81
I'm really confused and lost. A bit more clue-ins, please?
  • #82
The op-amp has a pair of power connections. This is where the op-amp gets the power to do what it does. The op-amp can only provide an output voltage that lies between the positive power supply and the negative power supply voltages. If you apply inputs that would cause the op-amp to "want" to create an output that is higher than the positive supply voltage, or less than the negative supply voltage, the op-amp can only reach those limits.
What conditions will make the op-amp drive the output to one power supply level or the other? For an ideal op-amp, ANY voltage difference on the inputs will do it!
For this circuit the positive power supply for the op-amp is Vs = 7.8V. The negative supply voltage is zero because the negative supply lead for the op-amp is connected to ground (zero volts). So the output of the op amp is restricted to the range 0 ≤ Vo ≤ 7.8 .
Does that help?
  • #83
Are you telling me that Vout in case 2 = 0V ?
  • #84
I suppose I am :smile:
  • #85
Ah...because no matter what's my V there, as long as it's in minus, it automatically turns into 0 because the transistor minus leg is ground?
EDIT:
BTW one of my classmates looked at me oddly when I presented this formula:
Vout = (V+ - V-) x 1000000
As though we don't need it to solve the problem. Is it needed, or not?
  • #86
Well, op-amp rather than transistor (an op-amp actually contains a whole bunch of transistors). The basic rules are: the op-amp output cannot exceed the power supply levels, and any voltage difference between its inputs will drive it to one level or the other.
This applies to ideal op-amps. Real ones come very close to this behavior, too. So much so that one can usually ignore any discrepancies for purposes of analysis.
EDIT: No, you don't really need that formula, but if it helps you to remember which direction the op-amp is going to drive the output by all means keep it handy. Maybe replace the 1000000 with a big G or A or something that won't attract undue remarks :smile:
  • #87
Oops! Mistyped. meant op-amp :)
Ah, of course! I feel so stupid missing all the hints ILS gave me!
LOL. Got it :wink:
Thanks! Will scan full solution soon
  • #89
Looks fine to me! :smile:
  • #90
Terrific :smile: thanks!
