Op Amp with frequency compensation input
  • Thread starter Thread starter Joseph M. Zias
    Frequency Opamp
The discussion centers on the search for a modern operational amplifier (op-amp) that features a frequency compensation input, similar to the older uA709 model. The original poster is revisiting a feedback loop circuit and has acquired several uA709s but is interested in contemporary alternatives. There is an emphasis on the ability to tailor the op-amp's response for experimental purposes, such as inserting a right half-plane zero in the feedback loop. Participants are encouraged to provide information on available op-amps that meet these specifications. The conversation highlights the need for modern components that retain the unique functionalities of older designs.
Joseph M. Zias
Does anyone know of a modern op-amp (available) with a frequency compensation input as the very old 709 had?
I'm not finding anything with my searches so far. Can you say more about the application and specs you need to achieve?
Revisiting a feedback loop circuit of decades ago. I have two uA709s and 3 more on the way (Ebay). But I thought I would check to see if any "new" op amps have the same feature. Being able to tailor the response allows for some interesting experiments, for example, inserting a right half plane zero in the overall loop.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
