I Open channel flow: derive function for energy slope on friction?
To determine the normal flow depth in a horizontal circular conduit using Manning's equation, the energy slope must be established, which is influenced by gravity and friction. In a level conduit, the fluid surface will have a gradient, and this slope should be incorporated into the Manning equation. If the cross-sectional area decreases significantly downstream, the analysis may need to be conducted in segments. Reference materials such as HDS 5: Hydraulic Design of Highway Culverts can provide valuable insights, although caution is advised regarding potential inaccuracies in some nomograms. Understanding these principles is essential for accurate hydraulic calculations in conduit flow scenarios.
MrS
TL;DR Summary
Manning's formula is not usable when the energy slope is unknown in a horizontal system. Can I determine this slope if I only know a discharge and some system characteristics (pipe diameter & roughness)?
I want to determine the normal flow depth in a perfectly horizontal circular conduit. The system characteristics are known (Internal pipe diameter, Mannings roughness, Discharge). However, I am not sure how to calculate the normal flow depth. When using Manning's equation one can find the normal flow depth, however this formula consists of the energy slope which is unknown (and dependent on h). How should I solve this? I think there should be, with assuming normal flow conditions, a way to write the energy slope as function of gravity and friction. Is there anyone who has ideas on how to do that or has another solution?
Thanks in advance!
In order to have gravity flow, there must be a gradient. If the conduit is level, then the fluid surface will have a gradient. Use the fluid surface slope in the Manning equation. If the gradient is only in the fluid depth, then the flow cross sectional area will decrease in the downstream direction. If the change in cross sectional area is greater than about 10% or so, the solution would be done in parts.
You might get some good ideas from HDS 5: Hydraulic Design of Highway Culverts, 3rd Edition. It's available online: https://www.fhwa.dot.gov/engineering/hydraulics/pubs/12026/hif12026.pdf. Culvert flows can be under inlet control, outlet control, or in a transition regime. Your case has an energy slope with zero bed slope. Be aware that at least one of the nomograms in that document is wrong by more than an order of magnitude. The text and equations are good, though.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
