MHB Operator Norm for Linear Transformations: Browder Ch. 8, Section 8.1, Page 179
Math Amateur
MHB
The "Operator Norm" for Linear Transfomations ... Browder, page 179, Section 8.1, Ch. 8 ... ...
I am reader Andrew Browder's book: "Mathematical Analysis: An Introduction" ... ...
I am currently reading Chapter 8: Differentiable Maps and am specifically focused on Section 8.1 Linear Algebra ...
I need some help in fully understanding some remarks by Browder concerning the "operator norm" for linear transformations ...
The relevant notes form Browder read as follows:https://www.physicsforums.com/attachments/7451
My questions regarding the above text by Browder are as follows:
Question 1
In the above notes from Browder we read the following:
" ... ... A perhaps more natural way to define the distance between linear transformations is by using the so-called "operator norm" defined by
$$\lvert \lvert T \rvert \rvert = \text{ sup} \{ \lvert Tv \rvert \ : \ v \in \mathbb{R}^n , \ \lvert v \rvert \le 1 \}
$$It is not hard to verify that this definition is equivalent to $$\lvert \lvert T \rvert \rvert = \text{ inf} \{ C \ge 0 \ : \ \lvert Tv \rvert \le C \lvert v \rvert \text{ for all } v \in \mathbb{R}^n \} $$
Can someone please demonstrate rigorously exactly why/how
is equivalent to
Question 2
" ... ... The finiteness of $$\lvert \lvert T \rvert \rvert$$ is easy to see ... "Can someone please rigorously demonstrate why/how $$\lvert \lvert T \rvert \rvert$$ is necessarily finite ... ?
Help will be much appreciated ... ...
Peter
Re: The "Operator Norm" for Linear Transfomations ... Browder, page 179, Section 8.1, Ch. 8 ... ...
Hi Peter,
Peter said:
Question 1
is equivalent to
If $v\in \Bbb R^n - \{\bf 0\}$, then $\dfrac{v}{\lvert v\rvert}$ has norm $1$, so $\left\lvert T\left(\dfrac{v}{\lvert v\rvert}\right)\right\rvert \le \|T\|$. Since $T$ is linear, $T\left(\dfrac{v}{\lvert v\rvert}\right) = \dfrac{1}{\lvert v\rvert}T(v)$. Thus $\lvert T(v)\rvert \le \|T\|\lvert v\rvert$. Since $T$ is linear, $T(0) = 0$, so the inequality $\lvert T(v)\rvert \le \|T\|\lvert v\rvert$ holds for $v = 0$. Since $\lvert Tv\rvert \le \|T\|\lvert v\rvert$ for all $v\in \Bbb R^n$, then $\|T\|$ is an element of the set $\{C\ge 0 : \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}$. Therefore,
$$\|T\| \ge \inf\{C\ge 0: \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}\tag{1}\label{eq1}$$
On the other hand, if $C > 0$ such that $\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$. In particular, for all $v\in \Bbb R^n$ with $\lvert v\rvert \le 1$, $\lvert Tv\rvert \le C$. Hence, $\sup_{\lvert v\rvert \le 1} \lvert Tv\rvert \le C$, i.e., $\|T\| \le C$. This shows that $\|T\|$ is a lower bound for the set $\{C\ge 0: \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}$. Hence, $$\|T\| \le \inf\{C\ge 0 : \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}\tag{2}\label{eq2}$$ By inequalities \eqref{eq1} and \eqref{eq2}, the result follows.
Peter said:
Question 2
Let $\mathbf{e}_1,\ldots, \mathbf{e}_n$ be the standard basis of $\Bbb R^n$. For all $\mathbf{v} = (v_1,\ldots, v_n)\in \Bbb R^n$, $$T(\mathbf{v}) = T\left(\sum_{i = 1}^n v_i \mathbf{e}_i\right) = \sum_{i = 1}^n v_i T(\mathbf{e}_i) = \mathbf{v}\cdot (T(\mathbf{e}_1),\ldots, T(\mathbf{e}_n))$$ The Cauchy-Schwarz inequality gives $\lvert Tv\rvert \le C\lvert \mathbf{v}\rvert$ where $C$ is the norm of the vector $(T(\mathbf{e}_1),\ldots, T(\mathbf{e}_n))$. Note the $C$ a constant independent of $\mathbf{v}$. Since $\mathbf{v}$ was arbitrary, $\|T\| \le C$. Therefore, $\|T\|$ is finite.
Euge said:
Hi Peter,If $v\in \Bbb R^n - \{\bf 0\}$, then $\dfrac{v}{\lvert v\rvert}$ has norm $1$, so $\left\lvert T\left(\dfrac{v}{\lvert v\rvert}\right)\right\rvert \le \|T\|$. Since $T$ is linear, $T\left(\dfrac{v}{\lvert v\rvert}\right) = \dfrac{1}{\lvert v\rvert}T(v)$. Thus $\lvert T(v)\rvert \le \|T\|\lvert v\rvert$. Since $T$ is linear, $T(0) = 0$, so the inequality $\lvert T(v)\rvert \le \|T\|\lvert v\rvert$ holds for $v = 0$. Since $\lvert Tv\rvert \le \|T\|\lvert v\rvert$ for all $v\in \Bbb R^n$, then $\|T\|$ is an element of the set $\{C\ge 0 : \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}$. Therefore,
On the other hand, if $C > 0$ such that $\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$. In particular, for all $v\in \Bbb R^n$ with $\lvert v\rvert \le 1$, $\lvert Tv\rvert \le C$. Hence, $\sup_{\lvert v\rvert \le 1} \lvert Tv\rvert \le C$, i.e., $\|T\| \le C$. This shows that $\|T\|$ is a lower bound for the set $\{C\ge 0: \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}$. Hence, $$\|T\| \le \inf\{C\ge 0 : \text{$\lvert Tv\rvert \le C\lvert v\rvert$ for all $v\in \Bbb R^n$}\}\tag{2}\label{eq2}$$ By inequalities \eqref{eq1} and \eqref{eq2}, the result follows.Let $\mathbf{e}_1,\ldots, \mathbf{e}_n$ be the standard basis of $\Bbb R^n$. For all $\mathbf{v} = (v_1,\ldots, v_n)\in \Bbb R^n$, $$T(\mathbf{v}) = T\left(\sum_{i = 1}^n v_i \mathbf{e}_i\right) = \sum_{i = 1}^n v_i T(\mathbf{e}_i) = \mathbf{v}\cdot (T(\mathbf{e}_1),\ldots, T(\mathbf{e}_n))$$ The Cauchy-Schwarz inequality gives $\lvert Tv\rvert \le C\lvert \mathbf{v}\rvert$ where $C$ is the norm of the vector $(T(\mathbf{e}_1),\ldots, T(\mathbf{e}_n))$. Note the $C$ a constant independent of $\mathbf{v}$. Since $\mathbf{v}$ was arbitrary, $\|T\| \le C$. Therefore, $\|T\|$ is finite.
Thanks so much Euge ...
Really appreciate your help on this matter ...
Just working through what you have written ...
Thanks again ...
Peter
I am revising question 1 above ... where Euge is proving that $$\lvert \lvert T \rvert \rvert = \text{ sup} \{ \lvert Tv \rvert \ : \ v \in \mathbb{R}^n , \ \lvert v \rvert \le 1 \}
$$is equivalent to $$\lvert \lvert T \rvert \rvert = \text{ inf} \{ C \ge 0 \ : \ \lvert Tv \rvert \le C \lvert v \rvert \text{ for all } v \in \mathbb{R}^n \}
$$In the above proof by Euge ... Euge writes the following:" ... ... In particular, for all $v\in \Bbb R^n$ with $\lvert v\rvert \le 1$, $\lvert Tv\rvert \le C$. Hence, $\sup_{\lvert v\rvert \le 1} \lvert Tv\rvert \le C$, i.e., $\|T\| \le C$. ... ... "
Can someone please formally and rigorously demonstrate that ...if ... for all $v\in \Bbb R^n$ with $\lvert v\rvert \le 1$, $\lvert Tv\rvert \le C$ ... ...... it then follows that ... $\sup_{\lvert v\rvert \le 1} \lvert Tv\rvert \le C$ ... ... (It seems highly plausible ... but how do you rigorously prove it ... ? )
... help will be much appreciated ...
Peter
The statement "for all $v\in \Bbb R^n$ with $\lvert v\rvert \le 1$, $\lvert Tv\rvert \le C$" says that $C$ is an upper bound for the set $\{|Tv| : v\in \Bbb R^n,|v|\leqslant1\}$. The number $\sup_{\lvert v\rvert \le 1} \lvert Tv\rvert$ is the supremum, or least upper bound, of that same set. By definition, the least upper bound is less than or equal to any other upper bound. Therefore $\sup_{\lvert v\rvert \le 1} \lvert Tv\rvert \leqslant C$.
Thanks Opalg ...
That certainly clears up the issue ...
Peter
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
