Optical Activity: How Do Chiral Molecules Rotate Light?
Optical activity refers to the ability of chiral molecules to rotate plane-polarized light, a phenomenon resulting from the interaction of light's electric fields with the electron clouds of these molecules. When light interacts with a chiral molecule, the electric fields polarize the electron clouds, causing a shift in electron density. This polarization creates fluctuating dipoles that emit electrical fields. Due to the low symmetry of chiral molecules, these emitted fields do not align with the incoming light's polarization, resulting in a rotation of the polarization axis. Although molecules in solution can orient in various directions, only certain orientations significantly contribute to the rotation of light, while others can be disregarded. The polarization of the electron cloud occurs as electric fields exert forces on electrons and nuclei, leading to a separation of charge centers, which varies with the light's frequency. This asymmetry in polarization causes the plane of polarization to rotate, explaining the optical activity of chiral substances.
Vivek des
"Optical activity is the tendency of chiral molecules to rotate ppl" how does a chiral molecule rotate light? Is it because of interaction of electric fields? Anyone please help me? I just need to know how a molecule physically does that?
Chemistry news on Phys.org
The electric fields of the optical wave polarize the electron clouds. The moving polarization of the electron clouds in turn leads to electrical fields which are partially emitted. However, the electric fields are not always emitted at the same point where the polarization and currents have been induced. If the resultant fields are furthermore rotated with respect to the incoming wave due to the low symmetry of the molecule, the polarization axis of the resultant field will be rotated.
I struggle with this concept myself too. In solution, molecules are rotated in every direction so you'd think that the polarisation induced by the electric field of the wave would be isotropic and cancel each other out. But I suppose only some of the orientations (meaning which way they're rotated) can rotate the light significantly, so the other orientations can be ignored.
I don't fully understand your explanation DrDu. When the incoming wave polarises the electron cloud, how does the emitted electrical field cause the incoming electrical field to rotate? Polarisation of electron clouds, that's just a shift of electron density isn't it? Is that what you mean by polarisation, or are you saying the electron waves get polarised in the same way light waves do? I think there should be a different term for EM polarisation, its more to do with anisotropy than polarity.
How does the electron cloud gets polarized? And even when it gets polarized due to the lights electric field how does it help to rotate the plane of ppl?
Electric fields exert forces on the electrons and oppositely on the nuclei. Hence the centers of charge will separate and you will get a polarisation varying with the frequency of the incoming light. However, if the molecule isn't symmetrical, the polarisation will not be strictly along the direction of the incoming field. Hence the field of the fluctuating dipoles will be tilted as compared to the incoming field, i.e. the plane of polarisation gets rotated.
Thanks a lot DrDu :)
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
