Optics: Focal length of Koenig eyepiece
The discussion centers on calculating the focal length of a Koenig eyepiece with specific lens parameters. The first lens is made of 755276 glass with defined thickness and radii, while the second lens shares a surface with the first and has its own specifications. The third lens, made of 607567 glass, is positioned with a 0.7 mm air gap from the second lens. The original poster struggles to derive the expected focal length of 100 mm using the provided formula, indicating a need for different equations for the first two lenses due to their glass and air interfaces. The conversation highlights the complexities of lens systems and the importance of using the correct optical equations for accurate calculations.
xspook
A Koenig eyepiece with a focal length of 100mm is constructed in the following way:
The first lens is made of 755276 glass which is 10 mm thick on axis. The radius of curvature of its left hand surface is -225mm, the radius of curvature of it right hand surface is 83.6 mm. The eyepiece is 130mm in diameter.
The second lens shares its left hand surface with the right hand first lens.
It has an axial thickness of 50 mm, and the radius of curvature of its right hand surface is (-102mm). The glass in the second lens is 623569.
The face of the third lens is located 0.7 mm from the right hand surface of the second lens. The gap is filled with air.
The third lens is 33.3 mm thick on axis. The radius of curvature of its left hand surface is 110 mm, the radius of curvature of its right hand surface is -458mm, and it is made of 607567 glass.
\frac{1}{f}=(n_{1}-1)[\frac{1}{R_{1}}-\frac{1}{R_{2}}+\frac{(n_{1}-1)d_{1}}{n_{1}R_{1}R_{2}}]
It is stated the eyepiece has a focal length of 100mm, so I assumed that using the equation above and plugging in numbers that I would get the focal length given to us. However I am unable to obtain 100mm. I tried to obtain a focal length for each lens and add them together, but I think the first and second lens need a different equation (since it has glass on one side and air on the other).
Attached is the system that I created from the given information
This is the third question on our homework, so the writing on it is from the first two questions.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
