Optimal Discrete Sampling of Histogram
The discussion centers on the challenge of optimal discrete sampling from a normalized histogram, aiming to minimize the difference between a sample histogram and the original population histogram. The problem can be classified as an "integer programming" issue, where the objective function measures the discrepancy between the two histograms. Participants explore how to define the number of samples per bin, denoted as c(i), while adhering to constraints on total sample size. A proposed method involves distributing samples based on the proportionate "deserving" scores of bins, though concerns about the need for sorting arise. Overall, the conversation highlights the complexity of achieving an optimal sampling strategy while acknowledging limitations in statistical independence.
Jarvis323
I am wondering if this problem has a name, and what is the most efficient way to solve it. Say you have a normalized histogram ##h(P)## (representing a pdf estimated from a large population), with ##n## bins, you want to generate a sample of points ##S## from ##h(P)## of size ##k##, such that $$\sum_{i=0}^{n-1}|h(S)_i - h(P)_i|$$ is minimized. Note that since the histogram is discrete, it is enough to select a ##c(i)## for each bin, where $$\sum_{i=0}^{n-1}c(i) = k$$ and the solution is minimal.
Technology news on Phys.org
How is ##c(i)## defined? Is it the number of elements selected that have a value equal to the value represented by the ##i##th bin? Is ##c(i) = k\ h(P)_i## ?
##c(i)## is just the number of elements you choose to generate in bin ##i##.
Another way of thinking about it is that you have ##k## apples to give out and ##n## people. Each person has a score ##p \in \mathbb{R}##, which says how deserving they are of apples. You want to give out the apples as fairly as possible according to ##p##. Since ##p## is continuous and you have discrete apples, some people may deserve slightly more than they get, or get more than they deserve.
I guess it seems somewhat simple, and I have an idea to do it efficiently, which is to just give everyone the number of apples they wholy deserve, and then sort the people according to how much apple they still deserve, and then just give the ##m## apples left over to the first ##m## people.
But it would be nice if you could do it without having to do the sorting.
I think what your are asking is illustrated by the following problem: Suppose there are 3 bins with ##h(P)_0 = 0.4, h(P)_1 = 0.4, h(P)_2 = 0.2##. and we want to generate a sample of size 11. We can't pick values of the ##c(i)## to make ##\sum_{i=0}^2 |h(S_)i - h(P)_i|## exactly zero. So what are the ways of assigning values to the ##c(i)## that minimize that sum?
Problems of this general type are called "integer programming" problems. The function ##C(c_0, c_2,...c_m) = \sum_{i=0}^{m} |h(S_)i - h(P)_i|## is the "objective function". The constraints are ## 0 \le c_i \le n ##, ##\sum_{i=0}^m c_i = n##, where ##n## represents the size of the sample to be generated.
I don't know what, if any, name is given to a problem with such an objective function. Your objective function is unusual because it does not depend on what the bins represent, but only on what fraction of the population they contain. A particular example of this problem may have more than one solution because two different bins might each contain the same fraction of the population and the distinction in what the two bins represent doesn't affect the objective function.
It's worth noting that if you generate a sample of size ##n## by minimizing the objective function, you are not generating ##n## independent random samples from the population, so theorems in statistics that apply to random sampling do not apply to generating samples in this manner.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
