Optimizing Outcomes: The Role of Probability in Choosing Boxes
  • Thread starter Thread starter KarateMan
    Choice Probability
The discussion focuses on a computer algorithm designed to analyze the optimal strategy in a box selection scenario similar to the Monty Hall problem. A participant describes a situation where a friend places $10 in one of three boxes, and after an initial choice, one empty box is eliminated. The key question is whether changing the initial choice increases the expected outcome. The consensus is that changing the choice does improve the chances of winning, as the algorithm confirms this finding. The Monty Hall problem is referenced as a well-known example illustrating this counterintuitive probability concept.
KarateMan
hi, I am writing a computer algorithm which descibes the change of choice.
1.your friend puts $10 in a box among three (there are three boxes) but you don't know which.
2.you choose one of them but do not open it.
3.your friend opens (eliminates) one of empty boxes
i.e. if you choose the lucky box, he eliminate either one of two empty boxes at equal probability
and if you choose an unlucky one, he eliminates the empty remainder.
4.then you decide, whether or not you change your choice between two remainings.
5.repeat 1~4 many times and expect the maximum result(in $).
Question: you'd better change your choice? or should not change? for the maximum outcome.
I expected that the change of choice should not matter: the equal probabilities.
but my computer algorithm tells that "if you change the choice, better"
Can someone tell me whether I am wrong or my algorithm is wrong?
The algorithm is right. Search for Monty Hall problem (here or on the search engine of your choice). It's a popular topic. In short: picking the remaining box is really as good as picking both remaining boxes, and there's a better chance it's in one of the two remaining boxes than in your original 1.
Thank you for such a quick reply!
I will check it out. but your explanation helped a lot, CRGreathouse!
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
