Optimizing Pin Diameter and Column Thickness for Hydraulic Press Design
The discussion focuses on optimizing the design of a 50-ton hydraulic press, particularly the vertical members and pin sizes. Concerns arise regarding the hole stresses in the steel, which suggest that thicker materials are necessary than those used in commercial machines. The use of plastic design principles is proposed to allow some yielding, potentially reducing material requirements and stress concentrations. Suggestions include using fewer holes in the vertical columns and considering collar fittings to distribute pin loads more effectively. The conversation emphasizes the need for a justifiable design while exploring the balance between strength and material efficiency.
Turbine
Hi guys,
Working on a 50-ton hydraulic press design using a standard H-frame design, like this:
I'm working on the design of the vertical members. Similar to the photo above, the verticals have 1.25" diameter holes drilled for pins that support the horizontal bed. The problem: while determining the size of steel to use, I'm finding that the hole stresses require a much thicker steel than what I see being used in commercial machines.
Specifically, in order to support the maximum 50-ton load, that equates to 25,000 lbf per vertical support. If I use two 1.25" pins per side (4 total) to support the horizontal bed, that works out to 12,500 lbf of force per hole.
I've modeled a 1"x4" A36 flat bar at some length with 1.25" dia. holes space 5" apart. The base is fixed, there is a bearing force of 12,500 lbf per hole (so 25,000 lbf total), and a reaction force of 25,000 lbf along the top of the bar. Running SolidWorks Simulation, I get the following:
The max stress is in the top hole, 27,600 psi. While this is OK, if I use, say, 1/2" plate, it yields. Commercial units I've seen use 1/2" or less. Many only use a single pin per side. I just don't get it. Am I doing something wrong here? Are the manufactures not taking into account the hole stresses? Are they not as important as I'm suspecting?
Any feedback would be greatly appreciated. Thank you!
Plastic design can greatly reduce the mass of a design since it takes a small amount of the material safely past the yield point. Maybe you should consider plastic deformation of the hole. Allowing some yield will limit the peak stress as the force is then spread over a greater area.
I use induction hardened, high tensile hydraulic rod for the pins. Since pins must be slightly smaller than the holes there needs to be a pear shaped deformation of the holes to bear the full load on the surface of the pin.
The bed is usually made from channel, so the pin is against, and deforms the flat flange. That is not good for the bed channel's web, or the pin. For heavier presses, the bed needs to have holes through thicker plate or collars.
The presses that use 4 vertical bars tend to be a bit unstable as the misalignment of the head and bed can eject the tool or work piece. It is better to use a single channel for the vertical on either side. Select or fabricate channel with a heavy flange.
Vertical hole separation of 5” gives you 5” steps. You might consider drilling less holes in the vertical columns. By drilling two holes, one above the other in the bed, say 3” apart, you can then use less holes, say 6” apart, in the vertical, to get 3” steps. My last press design used three holes in the bed to give a “vernier” choice of bed height and so better utilisation of the ram length without unstable packing.
Likes Turbine
Excellent information! Thank you very much. I am working on this as a senior capstone project for mechanical engineering. We're taught so much to keep things below yield, not much has been discussed in my courses about designing in the plastic region. I discussed this with one of my professors today, who is a licensed PE, and he did agree. Although for the purpose of this project, they may not want us to produce a design that is yielding. I'm still working on clarification there.
C-channel was looked at for the vertical members (and is preferred), but standard C-channel is tapered and the hole stresses required the change to use flat bar. With some allowable yielding, that would certainly open back up the possibility to use C-channel, or plate bent to such a shape. Obviously the commercial units work, so I don't doubt the design. We just need to produce a justifiable design.
Use of a single pin per side would also be preferred, but again, with the hole stresses simulated, distributing the loads over two pins per side was needed to prevent yielding. I'll continue to dive into understanding plastic design better. If you know of any specific resources that may help, please let me know. Thank you!
I think you misunderstood my suggestion. I suggest only one pin per side, but two possible holes, in the bed, one above the other. That halves the number of holes needed in the columns for the same bed position step size.
If the holes in lighter columns were fitted with collars to spread the pin load, halving the number of collars would be a saving worth taking.
For shear, the cross-section area of the pin rises with the square of the diameter, but the pin bearing area only rises linearly with diameter, and with column thickness. Have you solved for optimum pin diameter and therefore column thickness?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
