Orbital angular momentum possible values of an electron in a hydrogen atom
The possible values for the orbital angular momentum of an electron in a hydrogen atom with a principal quantum number n = 3 are determined by the quantum number l, which can take values of 0, 1, and 2. Using the formula L = √(l(l+1))ħ, the corresponding angular momentum values are 0, √2ħ, and √6ħ. The calculations confirm that these values are correct. The discussion concludes with a confirmation of the solution's accuracy.
Ezequiel
What are the orbital angular momentum possible values for an electron in a hydrogen atom with a principal quantum number n = 3?
L = \sqrt{l(l+1)}\hbar
Possible values for l are 0, 1, 2.
So, substituting these in the equation above I get: 0, √2\hbar, √6\hbar.
Is this the right answer?
yep, that looks right.
Thank you again :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
