I Orbital distance increase during the white dwarf phase of the Sun
The discussion centers on the estimated mass loss of the Sun during its white dwarf phase, potentially reducing its mass to about 50% of its current value. This reduction in mass would lead to a decrease in gravitational pull, causing the orbits of celestial bodies like Pluto to expand outward. Participants explore the calculation process for determining the new orbital distance, utilizing the relationship between orbital speed and radius derived from gravitational and centripetal forces. Conservation of angular momentum is also highlighted as a crucial factor in these calculations. Understanding these dynamics is essential for predicting the future positions of objects in the solar system.
Dreksler
TL;DR Summary
Want to know as to how to calculate orbital distance of bodies in the Solar system during the white dwarf phase of the Sun.
Some estimates through calculating the sun mass loss and increase in mass loss say that the white dwarf phase of the Sun will have roughly about 50% the current mass of the Sun (not sure about it). Whatever the actual mass loss is going to be, assuming that the 50% mass loss is true, where would that approximately put the orbit of let's say Pluto, how much outward will it expand due to a lower gravitational pull from the Sun, and what is the calculation process?
Astronomy news on Phys.org
You have an equation relating orbital speed to radius (derived from gravitational force = "centripetal force").
Then use conservation of angular momentum.
Likes Vanadium 50 and Dreksler
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
