Orbital energy and Electronic Configurations
In summary, the Bohr-Bury rule is an approximation, Actinides have no clear electronic configurations, and it's difficult to predict the energetic state of an electron based on its position in an atom.
gemma786
29
Hi
I have questions related to the electronic configurations of elements of d and f-block.
First I want to ask a question about the E.C. of Lanthanium. This element has E.C. [Xe]5d16s2, but according to Bohr-Bury rule 4f-orbitals should be filled prior to 5d-orbital and then Lanthanium’s E.C. should be [Xe]4f16s2, isn’t? AND this is also the case with Gadolinium in which one electron is promoted to 5d orbital leaving behind half filled 4f-subshell.
AND when we go through the electronic configurations of Actinoids why we find so many ambiguity in their electronic configurations?
At last, suppose effective nuclear charge increases by same amount for 3d , 4d and 5d orbitals for different atoms then in which of these orbitals does the orbital energy will decrease most?
The Bohr-Bury scheme says a shell has 2n2 electrons. You're thinking of the Madelung rule. But the Madelung rule is not absolute, it's merely an approximation. You don't need to go further down the periodic table than Chromium before you find "violations" of it.
Not the same phenomenon for Lanthanum, but the same as for Chromium; filled and half-filled orbitals have additional stability due to the Pauli principle/exchange energy.
Actinides. There's no ambiguity; but there's no reason to assume that there would be any simple regularity. The energetic state of every electron depends on that of every other electron, and an atom like Gadolinium has as many electrons as an organic molecule. It depends on the correlation of the electronic motion, which is notoriously difficult to predict, on the exchange energy, which is purely quantum-mechanical, and for heavy elements you have to take into account the effects of special relativity on the core electrons, and spin-orbit coupling effects, as well as effects from the geometric properties of f-orbitals, which shield the nucleus to a significantly smaller extent than the rest.
Thanks to the fact that the energy gap between sub-shells is often relatively large, we have a general 'rule' that holds rather well, under the circumstances. But there's no reason to assume it should always hold.
If you neglect exchange and correlation, they would all change by the same relative amount, proportional to Z2. But you can't accurately model even the core electrons simply as an effective nuclear charge, much less the valence electrons, precisely because of this. It's of no explanatory value for understanding the subtle effects involved in the deviations from Madelung's rule.
Thankyou very much alxm.
I think I need to do a lot of work on quantum mechanics but the stream opted by me doesn't allows me do so !
But anyways thanks.:wink:
Related to Orbital energy and Electronic Configurations
1. What is orbital energy?
Orbital energy refers to the energy level of an electron within an atom's electron cloud. This energy is determined by the distance of the electron from the nucleus and its specific location within the atom's orbitals.
2. How is orbital energy related to electron configurations?
Electron configurations are determined by the arrangement of electrons within an atom's orbitals, which in turn are influenced by the orbital energy levels. The lowest energy orbitals are filled first according to the Aufbau principle, resulting in the specific electronic configuration of an atom.
3. Can orbital energy change?
Yes, orbital energy can change if an electron gains or loses energy. This can happen through interactions with other particles or through the absorption or emission of photons. The energy change can also result in the electron moving to a different orbital.
4. How does the Pauli exclusion principle affect electronic configurations?
The Pauli exclusion principle states that no two electrons in an atom can have the same set of quantum numbers. This means that electrons must have opposite spins within the same orbital, resulting in different energy levels and influencing the electronic configuration of an atom.
5. What is the relationship between orbital energy and the periodic table?
The periodic table is organized based on the electronic configuration of elements, which is in turn determined by the arrangement of electrons within orbitals. Therefore, the orbital energy levels play a crucial role in understanding the organization and properties of elements in the periodic table.
  • Quantum Physics
  • Atomic and Condensed Matter
  • General Math
