MHB Order of operations to simplify expressions .
The expression 3(-3) - (5)2^2 simplifies to -29, while the denominator 8 - SQRoot(36) + 12 simplifies to 14. Therefore, the overall fraction is -29/14, not 11/14 or 5.5 as initially calculated. The calculations confirm that the correct answer is indeed a negative fraction. It's essential to carefully follow the order of operations to avoid errors in simplification.
rachealfarr
Hi, I have worked the problem but I am not sure that this is the correct answer, Please help.
3(-3) - (5)2^2
____________
8- SQRoot(36) +12 I got an answer of 11/14
but When I check on an online calculator to see if it is correct I am getting 5.5 ...
2^2 = TWO SQUARED
SQRoot = Square root of
Thank you :)
Mathematics news on Phys.org
Welcome, rachealfarr. (Wave)
The fraction
$$\frac{3(-3) - (5)2^2}{8 - \sqrt{36} + 12}$$
cannot be equal to either $11/14$ or $5.5$. It's a negative number: $3(-3) - (5)2^2 = -9 - (5)4 = -9 - 20 = -29$ and $8 - \sqrt{36} + 12 = 8 - 6 + 12 = 2 + 12 = 14$, hence the fraction is $-29/14$.
Could you check again to make sure you have the right fraction?
$$\frac{3(-3)-(5)2^2}{8-\sqrt{36}+12}=\frac{3(-3)-(5)4}{8-6+12}=\frac{-9-20}{8-6+12}=-\frac{29}{14}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
