MHB Order of Ops: PEMDAS Explained w/ Examples
  • Thread starter Thread starter Marvin Kalngan
    Operations
PEMDAS is an acronym that helps remember the order of operations in mathematics, standing for Parentheses, Exponents, Multiplication and Division, and Addition and Subtraction. Parentheses take precedence over exponents, which are followed by multiplication and division (at the same level), and finally addition and subtraction. When operations of the same rank occur, they should be processed from left to right. The discussion clarifies that expressions like 6(3) and 4(4) represent multiplication, and 16/4(4) simplifies to 16/4 × 4, resulting in 16. The "P" in PEMDAS specifically denotes Parentheses as a grouping sign.
Marvin Kalngan
The Order of Operations: PEMDAS
“A common technique for remembering the order of operations is the abbreviation "PEMDAS", which is turned into the phrase "Please Excuse My Dear Aunt Sally". It stands for "Parentheses, Exponents, Multiplication and Division, and Addition and Subtraction". This tells you the ranks of the operations: Parentheses outrank exponents, which outrank multiplication and division (but multiplication and division are at the same rank), and these two outrank addition and subtraction (which are together on the bottom rank). When you have a bunch of operations of the same rank, you just operate from left to right. For instance, 15 ÷ 3 × 4 is not 15 ÷ 12, but is rather 5 × 4, because, going from left to right, you get to the division first.”
But according to my book, 6(3) means “6 times 3”.
So,
16/4(4) = ? is the same with 16/4*4 = ?
because
4(4) means “4 times 4”
and
4*4 means “4 times 4”
It was not stated if P in PEMDAS stands for P as a sign of grouping or P as a sign of multiplication.
Sources:
College Algebra by William Hart 4th edition, page 5
Mathematics news on Phys.org
So,
because
and
Sources:
Hi Marvin! :)
That is correct.
6(3) is shorthand for $6 \times (3)$.
So:
$16/4(4) = 16 / 4 \times (4) = 4 \times 4 = 16$
And P in PEMDAS stands for Parentheses, which groups an expression.
The operation applied to it can be anything.
If no operation is specified, than multiplication is intended.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
