Origin of Tension: Newton's 3rd Law or Electrostatic?
  • Thread starter Thread starter PFuser1232
    Origin Tension
The tension force in elastic springs and strings is fundamentally linked to Newton's third law, which applies regardless of the material composition. Most objects are held together by electromagnetic forces, with exceptions for atomic nuclei and gravitationally bound massive objects. Tension arises when a spring or string is pulled from both ends, creating a balance of forces among individual atoms, which can be viewed as tiny springs themselves. This interaction illustrates that tension and the electromagnetic forces within the material are interconnected. Ultimately, understanding tension involves recognizing the balance of forces at play when an object is distorted or held in equilibrium.
PFuser1232
Does the tension force in elastic springs and strings arise inevitably as a consequence of Newton's third law? Or is it due to the electrostatic forces within the material itself? Or are both of these explanations basically the same thing?
Likes poseidon721
You've got it - they are the same thing.
Newton's 3rd law holds "regardless" of how the rope is made, or held together. But in fact almost everything you will ever encounter directly is held together by electromagnetic forces. The exceptions are atomic nuclei, hadrons, and massive objects held together by gravitation - like the Earth or moon.
Likes poseidon721
But doesn't tension appear only when the spring or string is pulled from both sides?
Likes poseidon721
Yes, but it still works that way.
You can treat each individual atom in the spring or string as a tiny spring fastened to its neighbors, and subject to Newton's third law. Tension is when these springs are stretched and compression is when those springs are compressed, and you can't do either unless you're pushing/pulling both ends of the object (if you only push/pull at one end, the forces are imbalanced and the object moves away/towards you instead of compressing/stretching). But either way, each individual atom/spring is being pushed/pulled by its neighbors, and exerting equal and opposit forces on them.
The attachments and forces within and between these 'tiny springs" are the electromagnetic forces you asked about in your original post.
Likes poseidon721 and PFuser1232
Yes. If the spring / string has no mass you cannot get any tension in it unless something is attached to the other end. You have to be either distorting something, keeping equilibrium with another external force or accelerating it.
In the same way, you can't 'push' against 'nothing'. Press-ups work as an exercise but Press-downs are useless.
Likes poseidon721
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 22 ·
  • · Replies 27 ·
24K
