I Orthogonal transformations preserve length
lys04
Let Q be an orthogonal matrix, and I want to transform (p,q), the magnitude of this vector is sqrt(p^2+q^2) using pythag. T((p,q))=pv1+qv_2 where v1 and v2 are the column vectors of Q. Since the column vectors of Q have magnitude of 1, this means pv1 has magnitude of p and qv2 has magnitude of q. v1 and v2 are also perpendicular, using the fact that ||a+b||^2=(a+b).(a+b)=a.(a+b)+b.(a+b)=a.a+a.b+b.a+b.b=a.a+0+0+b.b=||a|^2+||b||^2, so the magnitude of pv1+qv_2 is also sqrt(p^2+q^2). Hence length is preserved?
Also does this explain why orthogonal transformations have eigenvalues of magnitude of 1?
By definition, an orthogonal matrix satisfies A^T = A^{-1}. An immediate consequence is that for any v,
\|Av\|^2 = (Av) \cdot (Av) = (Av)^T(Av) = v^TA^TAv = v^Tv = v \cdot v = \|v\|^2 so that \|Av\| = \|v\|. If v is an eigenvector with eigenvalue \lambda, then <br /> \|v\| = \|Av\| = |\lambda| \|v\| \quad\Rightarrow\quad |\lambda| = 1.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
