Orthohydrogen to Parahydrogen: What particle?
The discussion centers on the transition of diatomic hydrogen molecules from Orthohydrogen to Parahydrogen, specifically the emission of a photon during this cooling process. It explains that at infinite temperature, hydrogen molecules are equally likely to occupy any of their four spin states, resulting in a fixed ortho- to para- ratio of 3:1 due to the three spin states available for ortho hydrogen. As temperature decreases, lower energy states become more favorable, allowing for a higher proportion of para hydrogen. At very low temperatures, the likelihood of occupying the lower energy state increases significantly, leading to a complete transition to para hydrogen at absolute zero. This highlights the relationship between temperature and the distribution of hydrogen spin states.
Chalmers
What subatomic particle is emitted when a diatomic Hydrogen molecule transitions from Orthohydrogen to Parahydrogen? e.g. during cooling
And why can you cool a sample of Hydrogen to assure that all H2 molecules are para-, but you cannot heat to have any more than 3:1 ortho-:para- ?
I assume a photon.
Well, what's the difference between ortho- and para-?
The short reason is that in the limit of infinite temperature, any given hydrogen molecule is equally likely to be in anyone of its four spin spin states. Since there are three spin states for ortho hydrogen and only one for para hydrogen, you get a fixed proportion of 3:1 even in the limit of infinite temperature.
At lower than infinite temperatures, lower energy states will be more likely to be occupied. Still, since there are three times as many high energy spin states to low energy spin states, you can have equilibrium proportions near 3:1 even at room temperature.
At very low temperatures (relatively speaking), the lower energy state is so much more likely to be occupied than any higher energy state, that the proportion goes down and down, until at absolute zero, you get a proportion of 0:1, with all the hydrogen being para hydrogen.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 28 ·
