Orthotropic materials defined by 9 constants
The discussion revolves around understanding the nine constants that define orthotropic materials, specifically how they relate to material symmetry and stress-strain relationships. Participants clarify that the constants reflect the material's symmetry, with the stress-strain relationship being tensorial in nature. The conversation highlights the relationship between Young's modulus, Poisson's ratio, and shear modulus, and how these relate to the constants C11, C22, C33, and others. There is a focus on the need for foundational knowledge of isotropic materials before delving deeper into orthotropic constants. Overall, the exchange aids in clarifying the complexities of orthotropic material properties and their mathematical representation.
johnjaypl
Could some one explain, or give me a pointer to a good explanation, of how the nine constants that are often used to define orthotropic materials are determined.
I understand what E is in each direction.
I understand poisson ratio.
I sort of understand G. (I understand it as the E equilivent for shear- is that right)
I don't understand D1111, D2222, etc.
I seam especially confused by G12, G13, and G23.
Thanks,
John
If I understand what you are asking, the number of independent material constants reflect the amount of symmetry in the material.
Most generally, the stress-strain relationship is tensor in nature:
\boldsymbol{\sigma} = \mathsf{c}:\boldsymbol{\varepsilon}
It's important to realize that the stress and strain terms themselves can be applied not only to mechanical behavior, but electrodynamic as well via, for example, the Maxwell stress tensor.
writing it out explicitly:
\sigma_{ij} = c_{ijk\ell}~ \varepsilon_{k\ell}
For mechanics, given a material with *no* symmetry,the 9 stress components are related to the 9 strain components via a 81-component tensor.
Symmetry reduces the number of independent components of the 4th rank tensor.
http://en.wikipedia.org/wiki/Orthotropic_material
About 1/2way down, there's some details.
Thanks. I'm so confused I can't even formulate a decent question. Let me try again.
What I'm trying to understand is described in the Orthotropic material section of this link
http://www.engin.brown.edu/courses/En222/Notes/Constitutive/Constitutive.htm
How do I go from understanding E (in 3 directions) v(in three directions) G(in three directions) to C11, c22, c33, c12, c13, c23, c44,c55, c66? What's the basic idea of what's going on here?
Thanks,
John
I didn't see a 'G' on that page, but did you follow the linear elasticity section down to the "Matrix form of the constitutive relations" section? That shows how these tensors can be written more compactly. The section "Elastic Symmetries" explains why some of 'c' components are zero- is that the part you are having trouble with?
Andy Resnick said:
I didn't see a 'G' on that page,...
I believe they use u (mu) for shear modulus. So:
c44 = u12 = G12
c55 = u13 = G13
c66 = u23 = G23
Is that right?
Is there a formula that allows one to calculate Gij from other properties?
.. but did you follow the linear elasticity section down to the "Matrix form of the constitutive relations" section? That shows how these tensors can be written more compactly. The section "Elastic Symmetries" explains why some of 'c' components are zero- is that the part you are having trouble with?
Well I started with more conceptional missunderstanding than that but at this point I get the idea of what's going on and why you want 9 constants and how the linear equations solve the stress/strain in all directions. So that's progress.
At this point I'm thinking I better go back and make sure I understand all of the basic relationships for isotopic materials. I mostly do but the releationships betwen E G and v are a bit fuzzy. But with some thought I think I can clear that up.
Then maybe I need a book to cover more details of the orthotopic material constants if I need to get that far into it. That is, why is that matrix set up the way it is, etc.
Even though my questions were fuzzy this exchange somehow helped me get over the major problem that I was having.
Thanks,
John
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
