Oscillatory motion equation in sine function
The equation y = A sin(kx - wt + pi/2) can be transformed into y = A cos(kx - wt), which is the correct answer to the problem. The confusion arose from the interpretation of phase shifts and the properties of sine and cosine functions. While the attempted answer d. was initially thought to be correct, it was clarified that both b. and d. can represent the same oscillatory motion under certain conditions. Understanding the relationship between sine and cosine, particularly through the phase shift of pi/2, is crucial in solving such equations. The discussion highlights the importance of recognizing these mathematical identities in physics problems.
grangr
The equation y = A sin(kx - wt + pi/2) is the same as
a. y = -A sin(kx - wt + pi/2)
b. y = A cos(kx - wt)
c. y = -A cos(kx - wt)
d. y = -A sin(kx - wt - pi/2)
e. y = A sin(kx - wt + (3pi)/2)
  • y = A sin[(2pi)/lamda * x - (2pi)/period * t + (phase constant)]
  • sin(x) = cos(pi/2 - x)
My attempted answer was d., while the correct answer given was b.
I do not understand why d. is wrong, as after a left shift of pi (from the '-pi/2' in the phase constant) in the sine function, when the sign is inverted (given the '-' before A), the resulting y should be the same. No?
I do not get why b. is the correct answer, either. Even with the fact that sin(x) = cos(pi/2 - x), wouldn't you get y = A cos(-kx + wt) then?Thanks in advance for your help! :smile:
Here's an answer :wink:
Likes grangr
OK, perhaps the long way around.
Realize sin(a+ pi/2) = cos(a)
a = kx-wt
Likes grangr and Nguyen Son
I did that because he/she knows that sin(x) = cos(pi/2 - x), like he/she said above, but he/she didn't know how to solve this problem with sin(x) = cos(pi/2 - x), so I did in that way :D
Sorry, I thought your post was the OP's answer. But you should not post complete answers, just hints.
##\cos(\theta) = \sin(\theta + \frac{\pi}{2}) = - \sin(\theta - \frac{\pi}{2})##
So, both b) and d) are correct.
Likes grangr
Thank you all, Nguyen Son, rude man, and Perok for your explanation. It is much clearer now. :partytime: (And it's good to know that both b) and d) are correct! :wink:)
Indeed, I totally did not recall that cos(x) = cos(-x), or that cos(θ)=sin[θ+(π/2)]. :doh: As it turns out, it wasn't a physics problem to me, but more of a math problem... :sorry:
