MHB Oxidation-Reduction in 2Ca + O2 -> 2CaO Reaction
  • Thread starter Thread starter markosheehan
    Reaction
In the reaction 2Ca + O2 -> 2CaO, calcium (Ca) is oxidized while oxygen (O2) is reduced. Each calcium atom has an oxidation number of +2 in CaO, while oxygen has an oxidation number of -2. The confusion arises from the understanding of electron transfer; oxygen gains two electrons, leading to its reduction. The discussion clarifies that both Ca and O2 are neutral before the reaction, and the oxidation states change upon forming CaO. This explanation resolves the initial misunderstanding regarding the oxidation numbers.
markosheehan
can some one show me by looking at electrons lost and gained which is oxidised and reduced in the reaction
2ca+o2->2cao
i would of said each calcium atom has a O.N of +2 and o2 has a O.N of 0
the o in 2cao has a O.N of -2 so that means the ca has a O.N of +2. but that makes no sense. where did as where did the oxygen gain the 2 electrons if the O.N of ca stays the same
im doing these questions wrong
Mathematics news on Phys.org
2ca+o2->2cao
Both $\ce{Ca}$ and $\ce{O2}$ are neutral.
In $\ce{CaO}$, $\ce{Ca}$ has oxidation number +2 and $\ce{O}$ has oxidation number -2.
$\ce{Ca}$ is oxidized and $\ce{O}$ is reduced.
2ca+o2->2cao
We have MathJax configured to handled chemical equations...for example the following code:
\ce{2Ca + O2 -> 2CaO}
produces:
$$\ce{2Ca + O2 -> 2CaO}$$
Here's more information:
Chemistry notation using mhchem
thanks i get it now
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
