Oxidizing iron bacteria made to work in reverse
The discussion centers on the operation of a biological water filtration plant where raw water is filtered through bacteria that oxidize ferrous oxide (Fe^+2) to ferric oxide (Fe^+3), effectively removing iron from the water. The backwash process generates water with high concentrations of Fe^+3 and some bacteria, prompting the inquiry into methods to reduce Fe^+3 back to Fe^+2. One proposed method involves adding glucose to create anaerobic conditions, allowing the bacteria to potentially reverse the oxidation process. However, there is uncertainty about whether the same bacteria can reduce iron under these conditions. Participants suggest conducting a literature search for more information on the enzymatic mechanisms involved in the reaction and recommend consulting a biochemistry department for expert assistance. The discussion highlights the need for a deeper understanding of the biochemical processes at play to effectively manage iron levels in the backwash water.
Rexmundi
My employer operates a biological water filtration plant. The first stage of filtration has the raw water passing through a filter embedded with bacteria, the processes used here is aerated biological treatment where oxidizing processes (bio-oxidation) are used and the microbes gain energy when they transform the ions from a reduced to an oxidized state.
Specifically in the first filter the bacteria oxidize all ferrous oxide to ferric oxide (Fe^+2 to Fe^+3) which is caught in the filter and when the water moves on to the next stage it is completely free of iron.
The large amount of rust build up in the first filter must be periodically cleansed by backwashing. When water is pumped backward through the filter it comes out with both a very very high concentration of Fe^+3 and a portion of the bacteria population.
What I am looking for is a way to reduce the iron in a sample of this backwash water back to Fe^+2. It has been suggested that perhaps an alternative energy source such as glucose could be added then the sample sealed so the bacteria would use all of oxygen present and create anaerobic conditions. In this environment might the very same bacteria that oxidized the iron begin to reduce it?
If not, are there other suggestions on how to accomplish this?
Biology news on Phys.org
If it helps I'll link to an article by Toni A. M. Bridge and D. Barrie Johnson
http://aem.asm.org/cgi/content/abstract/64/6/2181?maxtoshow=&HITS=10&hits=10&RESULTFORMAT=&titleabstract=iron+bacteria&searchid=1&FIRSTINDEX=0&resourcetype=HWCIT
This describes the process I'd like to emulate but my bacteria are living in water at about 10 degrees Celsius so are definitely not thermophiles.
Curious me, have you heard of Brachybacterium sp Mn32? :smile:
Interesting article. I only skimmed it, but there does not appear to be a mechanistic explanation for the reaction- what enzymes are involved? Once you know the players in the reaction, you can start to ask how to run the reaction in reverse.
I'd recommend doing a literature search (PubMed is a good place to start) to see if you can identify the reaction. And hie thee to a biochemistry department- someone there would be able to help.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
