MHB P-value: 0.0098Area of the critical region: 0.01Critical value(s): ±2.326
The discussion revolves around a hypothesis test regarding the XSORT method of gender selection, with a null hypothesis (H0) stating that the proportion of baby girls is 0.5, and an alternative hypothesis (H1) indicating it is different. The test is identified as two-tailed, with a calculated test statistic of z = 2.4. The P-value is determined to be 0.0098, which reflects the area under the normal curve for the given z-score. Participants discuss the use of the invNorm function on calculators to find the area necessary for calculating the P-value in a two-sided test. The conversation emphasizes understanding how to derive the critical region and P-value from the z-score.
noahpww
Use the following information to answer the questions below: A 0.01 significance level is used for a hypothesis test of the claim that when parents use the XSORT method of gender selection, the proportion of baby girls is different than 0.5. Assume that sample data consist of 62 girls born in 100 births, so the sample statistic of 0.62 results in a z score that is 2.4 standard deviation above 0.
(a) State the null hypothesis H0 and the alternative hypothesis H1.(b) State the type of test: Is the test two-tailed, left-tailed, or right-tailed?
Two-tailed.
(c) What is the value of the test statistic?
Test statistic: z = 2.4
(d) Find the P-value.(e) What is the area of the critical region?(f) Find the critical value(s)?
Any help with this would be greatly appreciated!
Mathematics news on Phys.org
Hi noahpww!
I agree that this is a two-sided test. If we have a z-score and a two sided test, how do we find the area necessary to calculated a p-value. Remember that a p-value is equivalent to an area under the normal curve here, it's just a question of how to find that area. Any ideas? :)
Do I use the invNorm feature in my calculator or the P-value Method?
I don't use a manual calculator these days, but yes I believe that the invNorm() function will return the area to the LEFT of a z-score. So now the question is how do we use that and our z-score to find the area of this two sided test?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
