MHB Panda Bear's question at Yahoo Answers regarding solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The discussion revolves around calculating the volume of a solid formed by revolving the region defined by the curve y = √(1-x), the lines x = -3, x = 1, and y = 1. The volume is computed using both the disk and shell methods, leading to the same result of V = 4π/3. The disk method involves integrating the function for the radius squared, while the shell method calculates the volume of cylindrical shells. Detailed calculations are provided for both methods, confirming the accuracy of the final volume. The thread effectively demonstrates the application of calculus techniques to solve the problem.
MarkFL
MHB
Here is the question:
Need calculus help Volumes using Disks/Washers?
find the volume of the solid that is obtained by revolving the region about the indicated axis or line
y=square root of (1-x )
x= -3, 1 y=1
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Panda Bear,
First, let's take a look at the region to be revolved:
Using the disk method, we see we will have two regions to revolve, the region on the left and the region on the right. However, since the radius is to be squared, and the radius on the right is the negative of the radius on the right, we may simply use one integral.
The volume of an arbitrary disk is:
$$dV=\pi r^2\,dx$$
where:
$$r=\pm\left(\sqrt{1-x}-1 \right)$$
and so we have:
$$dV=\pi\left(\sqrt{1-x}-1 \right)r^2\,dx=\pi\left(2-x-2\sqrt{1-x} \right)\,dx$$
Summing the disks by integrating, we have:
$$V=\pi\int_{-3}^1 2-x-2\sqrt{1-x}\,dx$$
For the third term in the integrand, let's use the substitution:
$$u=1-x\,\therefore\,du=-dx$$ and we have:
$$V=\pi\int_{-3}^1 2-x\,dx-2\pi\int_0^4u^{\frac{1}{2}}\,du$$
Applying the anti-derivative form of the FTOC, we find:
$$V=\pi\left(\left[2x-\frac{1}{2}x^2 \right]_{-3}^1-\frac{4}{3}\left[u^{\frac{3}{2}} \right]_0^4 \right)=$$
$$\pi\left(\left(\left(2(1)-\frac{1}{2}(1)^2 \right)-\left(2(-3)-\frac{1}{2}(-3)^2 \right) \right)-\frac{4}{3}\left(\left(4^{\frac{3}{2}} \right)-\left(0^{\frac{3}{2}} \right) \right) \right)=$$
$$\pi\left(12-\frac{32}{3} \right)=\frac{4\pi}{3}$$
We can check our work using the shell method. For the area on the left, we have:
The volume of an arbitrary shell is:
$$dV_1=2\pi rh\,dy$$
where:
$$r=y-1$$
$$h=\left(1-y^2 \right)-(-3)=4-y^2$$
and so we have:
$$dV_1=2\pi(y-1)\left(4-y^2 \right)\,dy=2\pi\left(-y^3+y^2+4y-4 \right)\,dy$$
Summing the shells, we find:
$$V_1=2\pi\int_1^2 -y^3+y^2+4y-4\,dy=2\pi\left[-\frac{1}{4}y^4+\frac{1}{3}y^3+2y^2-4y \right]_1^2=$$
$$2\pi\left(\left(-\frac{1}{4}(2)^4+\frac{1}{3}(2)^3+2(2)^2-4(2) \right)-\left(-\frac{1}{4}(1)^4+\frac{1}{3}(1)^3+2(1)^2-4(1) \right) \right)=$$
$$2\pi\left(\left(-4+\frac{8}{3}+8-8 \right)-\left(-\frac{1}{4}+\frac{1}{3}+2-4 \right) \right)=$$
$$2\pi\left(-\frac{4}{3}+\frac{23}{12} \right)=\frac{7\pi}{6}$$
Now, for the area on the right, we find the volume of an arbitrary shell is:
$$dV_2=2\pi rh\,dy$$
where:
$$r=1-y$$
$$h=1-\left(1-y^2 \right)=y^2$$
Hence:
$$dV_2=2\pi (1-y)\left(y^2 \right)\,dy=2\pi\left(y^2-y^3 \right)\,dy$$
$$V_2=2\pi\int_0^1 y^2-y^3\,dy=2\pi\left[\frac{1}{3}y^3-\frac{1}{4}y^4 \right]_0^1=2\pi\left(\frac{1}{3}-\frac{1}{4} \right)=\frac{\pi}{6}$$
Adding the two volumes, we find the total is:
$$V=V_1+V_2=\frac{7\pi}{6}+\frac{\pi}{6}=\frac{4\pi}{3}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
