MHB Parabola standard form of equation at x = -1
To find the standard form of a parabola with a vertex at the origin that passes through the point (-1, 1/8), the correct equations to use are y = ax^2 and x^2 = 4py. The vertex is at (0,0), leading to the equation y = ax^2, where substituting the point gives 1/8 = a(-1)^2, resulting in a = 1/8. Thus, the equation simplifies to y = (1/8)x^2 or equivalently x^2 - 8y = 0 in standard form. Both general equations provided are valid, as they represent the same parabola, confirming the approach taken is correct.
Joystar77
Find the standard form of the equation of the parabola with the given characteristics and vertex at the origin. Passes through the point (-1, 1/8); vertical axis.
I know that there is no focus of the parabola or equation given for this problem, so how would I solve this problem? Is the correct formula to use the following?:
x^2= 4py
Are these the correct steps to take?
1. Write original equation
2. Divide each side by number given.
3. Write in standard form.
Mathematics news on Phys.org
re: Parabola standard form of equation at x=-1
I have two different formulas for using the conic section of a parabola, can someone please tell me which is correct for this type of problem?
The first one is as follows:
Type: Parabola
General Equation: y = a (x-h)^2 + k
Standard Form: (x - h) ^2 = 4p (y-k)
Notation:
1. x2 term and y1 term.
2. (h,k) is vertex.
3. (h, k does not equal p) is center of focus, where p = 1/4a.
4. y =k does not equal p is directrix equation, where p = 1/4a.
Value:
1. a >0, then opens up.
2. a < 0, then opens down.
3. x = h is equation of line of symmetry.
4. Larger [a] = thinner parabola; smaller [a] = fatter parabola.
Type: Parabola
General Equation: x = a (y-k)^2 + h
Standard Form: (y-k)^2 = 4p(x-h)
Notation:
1. x1 term and y2 term.
2. (h,k) is vertex.
3. (h does not equal p, k) is focus, where p = 1/4a.
4. x = h does not equal p is directrix equation, where p = 1/4a.
Values:
1. a > 0, then opens right.
2. a < 0, then opens left.
3. y = k is equation of line of symmetry.
In this problem, find the standard form of the equation of the parabola with the given characteristics and vertex at the origin. Passes through the point (-1, 1/8); vertical axis. Would this problem be correct if I work it out this way?
Vertex is at (0,0), then is the equation y = ax^2?
1/8 = a(-1)^2
a = 1/8
y = (1/8)x^2
STANDARD FORM:
y = (1/8) x^2
8y = x^2
x^2 - 8y = 0
Is this the correct way to solve this problem? Which formula am I suppose to use? If this is not right, then can somebody please help me with this?
Re: Parabola standard form of equation at x=-1
Except for the fact that you have the parabola going through a point with x= -1 instead of x= -5, this is exactly the same as your post "Parabola standard form of equation at x= -4" and every answer there applies to this.
You ask "which of these formulas is correct for this type of problem
Standard Form: (x - h) ^2 = 4p (y-k)"
The answer is that they are the same formula except that the "a" in one is "1/4p" where p is from the other.
In both problems, the "vertex is at the origin" so h= k= 0 and the two equations become
General Equation: y = ax^2
Standard Form: x^2 = 4py
and, again, they are the same with a= 1/4p. Here, you are told that the graph goes through the point (-1, 1/8) so put x= -1, y= 1/8 into either and solve for a or p, as appropriate.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
