Durfys
- 2
Hey I came across this question in my textbook and the answer provided just does't make sense.
A circuit consists of a battery and 4 identical resistors in parallel. The current in each resistor is 12 A. If one of the resistors burns out, what will be the current in each of the remaining 3 resistors?
Book's explanation:
The battery remains the same and will provide the same voltage both with the 4 resistors and with the 3 resistors. Since the resistors are in parallel, the voltage drop on each must be the same as the voltage provided by the battery, and will be unchanged when one resistor burns out. Since both V and R are unchanged for each resistor by the burned out resistor, I is also unchanged for each resistor, and the current in each resistor is still 12 A. Note that what does change is the total current on the circuit, from 48 A with 4 resistors (4 × 12 A) to 36 A with 3 resistors (3 × 12 A). Since the resistors are in parallel, fewer resistors will mean a higher equivalent resistance, so the total current is reduced, even though the current on each resistor is unchanged.
I don't understand how the total current could change without any change to a single resistor's current. Can someone please clarify. Thanks very much in advance.
Book's explanation:
